Old 06-29-2017, 04:43 AM
migueldgoncalves migueldgoncalves is offline
Default Instrument Tracks Delay Compensation Bug
Hi guys,
I'm running PT 12.8 Standard.
Instrument tracks (with instrument inserts) don't seem to compensate for delay.
http://i.imgur.com/IlwKAmN.png
Aux tracks seem to behave fine, but as soon as I route a MIDI track to it, it kills the delay compensation.
http://i.imgur.com/esDrPY7.png
When I route multiple instrument tracks to one instrument insert, the delay compensation works properly within those routed tracks...
http://i.imgur.com/6j9gnKX.png
... But not with the other ones
http://i.imgur.com/MyS3p41.png
Anyone else experiencing this issue?
Cheers
Old 06-29-2017, 05:14 AM
JFreak's Avatar
JFreak JFreak is online now
Default Re: Instrument Tracks Delay Compensation Bug
Hi there. Your post was pending moderation because of the links. You need higher post count for automatic approval...
Janne
Old 06-29-2017, 05:43 AM
john1192 john1192 is offline
ooh .. Maxim PLugin on an instrument track while recording .. that is adding "One More Second" to the path while recording ..
"Advanced, look-ahead peak limiting" - i humbly think this plugin has too much latency to use during recording .. and it appears since this is an Instrument track that the Inserts are not being de-activated during recording ..
my .02 on that ..
i will leave the Delay Comp Q's to others until i look at your pictures a few more times ..
Mac Pro 6-core 3.33ghz (2012) 24gb ram 256gb SSD -OS 10.12.6 for PT 11.3.2 & 2019.6 last version
Logic Pro X latest version
RME BabyFace Pro
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS10.14.6 - PT 2019.6 Ended here ..
RME BabyFace Pro
Old 06-29-2017, 07:57 AM
I just inserted a random plugin to show the delay compensation bug.
Old 06-29-2017, 08:08 AM
thats a good one too ... !!!
RME BabyFace Pro
RME BabyFace Pro
Old 06-29-2017, 08:42 AM
c0c0p0ps c0c0p0ps is offline
Looks like it could be related to an issue I posted about yesterday here http://duc.avid.com/showthread.php?t=392028
I did not check if it was correctly reporting the delay compensation, as during playback everything sounds perfectly in time. It was just when bouncing or freezing that the Kontakt was out of time.
Am back on 12.7.1 for now as I need to finish a project but will then upgrade again and investigate further.
Delay Compensation on AUX tracks - automatic mesaone Pro Tools 11 12 07-21-2020 05:29 PM
Automatic Delay Compensation - PT 12.4 - Instrument Track bug swfeathers Pro Tools 12 8 09-04-2018 09:27 AM
11.2.1: Instrument Track delay compensation problem rainsong Pro Tools 11 14 08-20-2014 03:43 PM
Delay compensation and Aux Tracks Terry Wetzel Windows 10 04-08-2012 07:19 AM
Pro Tools 9 Delay and Delay Compensation on Aux Tracks and Bussing CNSound macOS 1 01-27-2012 11:10 AM
