Old 08-16-2012, 03:42 PM
Mechanix2 Mechanix2 is offline
Default Interface/Playback Engine Problem [solved]
Hey guys recently installed Pro Tools on my PC so I can record on that instead of using my Mac and I keep running into a problem.
Everytime I try and select my Fast Track C400 as my playback engine I get the error that "the selected ASIO device could not be initialized". I've re-installed the ASIO driver, re-installed the Fast Track driver and Pro Tools countless times and I always get this error.
Anyone know what's going on? Really irritated I can't find a fix for this.
Any help would be greatly appreciated!
System Information
Windows 7 64 bit Ultimate
12 GB RAM.
Pro Tools 10 10.0.0
Fast Track C400
I've done everything in the Setup and Troubleshooting Guide as well.
SiSoftware Sandra
ID
Host Name : Tracy-PC
Workgroup : WORKGROUP
Computer
Model : MSI MS-7636
Serial Number : To Be Filled By O.E.M.
Chassis : MSI Desktop
Mainboard : MSI H55M-E33(MS-7636)
Serial Number : To be filled by O.E.M.
BIOS : AMI (OEM) V1.10 01/26/2011
Total Memory : 11.87GB DIMM DDR3
Processors
Processor : Intel(R) Core(TM) i5 CPU 650 @ 3.20GHz (2C 4T 3.33GHz, 2.4GHz IMC, 2x 256kB L2, 4MB L3)
Socket/Slot : FC LGA1156
Chipset
Memory Controller : MSI Core (Arrandale) DRAM Controller 133MHz, 2x 6GB DIMM DDR3 1.33GHz 128-bit
Memory Module(s)
Memory Module : Mushkin 991770 4GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-25 4-34-10-5)
Memory Module : Corsair CMZ8GX3M2A1600C9 4GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-24 5-34-10-5)
Video System
Monitor/Panel : ACR Generic PnP Monitor (1920x1080, 23.4")
Video Adapter : NVIDIA GeForce GTS 250 (128 SM4.0 1.84GHz, 1GB DDR3 2.2GHz 256-bit, PCIe 2.00 x16)
Graphics Processor
OpenCL GP Processor : NVIDIA GeForce GTS 250 (128SP 16C 1.84GHz, 1GB DDR3 2.2GHz 256-bit)
Compute Shader Processor : NVIDIA GeForce GTS 250 (128SP 1.84GHz, 1GB DDR3 2.2GHz 256-bit)
CUDA GP Processor : NVIDIA GeForce GTS 250 (128SP 16C 1.84GHz, 1GB DDR3 2.2GHz 256-bit)
Storage Devices
WDC WD5000AAKS-00A7B2 (500.1GB, SATA300, 3.5", 7200rpm, 16MB Cache) : 466GB (C:)
HL-DT-ST DVDRAM GH22NS50 (7.6GB, SATA150, DVD+-RW, CD-RW, 2MB Cache) : 7GB (D:)
Disk (509.9MB, DVD+-R, CD-R, 512kB Cache) : 486MB (E:)
Disk (8.3GB, DVD+-R, CD-R, 512kB Cache) : 8GB (H:)
Disk (3.3GB, DVD+-R, CD-R, 512kB Cache) : 3GB (G:)
Disk (460.8MB, DVD+-R, CD-R, 512kB Cache) : 439MB (F:)
Logical Storage Devices
Hard Disk (C:) : 466GB (NTFS) @ WDC WD5000AAKS-00A7B2 (500.1GB, SATA300, 3.5", 7200rpm, 16MB Cache)
Pro Tools (D:) : 7GB (CDFS) @ HL-DT-ST DVDRAM GH22NS50 (7.6GB, SATA150, DVD+-RW, CD-RW, 2MB Cache)
FF7INSTALL (E:) : 486MB (CDFS) @ Disk (509.9MB, DVD+-R, CD-R, 512kB Cache)
CONVICTION (H:) : 8GB (UDF) @ Disk (8.3GB, DVD+-R, CD-R, 512kB Cache)
Civilization V (G:) : 3GB (UDF) @ Disk (3.3GB, DVD+-R, CD-R, 512kB Cache)
Torchlight (F:) : 439MB (CDFS) @ Disk (460.8MB, DVD+-R, CD-R, 512kB Cache)
Peripherals
LPC Hub Controller 1 : MSI H55 LPC Interface Controller
LPC Legacy Controller 1 : T0 07-23
Audio Device : MSI P55/PM55/3400 High Definition Audio
Audio Codec : Realtek Semi High Definition Audio
Serial Port(s) : 2
Parallel Port(s) : 1
Disk Controller : MSI P55/PM55/3400 4 port SATA IDE Controller
Disk Controller : MSI P55/PM55/3400 2 port SATA IDE Controller
Disk Controller : MSI JMB368 IDE Controller
USB Controller 1 : MSI P55/PM55/3400 USB2 Enhanced Host Controller
USB Controller 2 : MSI P55/PM55/3400 USB2 Enhanced Host Controller
SMBus/i2c Controller 1 : Intel ICH SMBus
Printers and Faxes
Printer : Microsoft XPS Document Writer (600x600, Colour)
Network Services
Network Adapter : Realtek PCIe GBE Family Controller (Ethernet, 1Gbps)
Operating System
Windows System : Microsoft Windows 7 Ultimate 6.01.7600
Platform Compliance : x64
Windows Experience Index
Current System : 5.9
Old 08-16-2012, 04:10 PM
Default Re: Interface/Playback Engine Problem
Guess I solved it. Not sure if the actual ASIO4All Driver and the C400 don't play well but I can now select my C400 for my Playback Engine after i uninstalled the ASIO driver. Weird but whatever works I suppose.
Old 08-16-2012, 07:22 PM
The Weed's Avatar
The Weed The Weed is offline
ASIOAll has been problematic on some systems.
Cheers,
non-union national read at a reasonable rate
Demos: brucehayward dot com
Source-Connect: brucehayward
Playback Engine Problem mrussaustin Pro Tools SE and Essential (Mac) 0 10-11-2012 05:09 AM
No m-audio interface in current engine (playback engine) SlicerSounds Windows 1 10-04-2012 12:27 AM
Playback Engine Setup Problem in PT 7.4.2 MattCraft Pro Tools TDM Systems (Mac) 1 07-07-2010 01:47 PM
Playback Engine Problem (-9136) thebends9 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 01-16-2006 11:40 PM
The midi-problem = solved with an interface? Nanok 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 07-03-2000 05:02 PM
