Old 12-01-2007, 11:49 AM
creator creator is offline
Default 96khz Issue (also affects M-Powered)
I thought I would post this here too since it was apparently tested under both Pro Tools M-Powered on Windows and Pro Tools LE on OS X.
In this post on KVR, testing EQs under different hosts (with an emphasis on Pro Tools LE/M-Powered) is discussed a lot with the implication that the Pro Tools RTAS versions of plug-ins such as Sonalksis SV-517 MK II don't work consistently at 96khz as compared to 48khz under Pro Tools LE/M-Powered as compared to consistent performance between the Audio Units and VST versions of the same plug-ins under different sample rates in multiple hosts on both Windows and Mac OS X.
Here is the link to the post KVR:EQ-ing at 96khz vs. 48khz
In the post a link is also given to audio files of the output of Sonar (as an example of a non-Pro Tools host EQ behavior) and Pro Tools, both at 48khz and 96khz with the exact same EQ settings in same plug-in.
Audio Examples
Can anybody explain why the Pro Tools example at 96khz sounds so different from all the others? It sounds almost like it is targeting a different EQ band.
m-powered protools max 14 channels of 96khz ciank Pro Tools M-Powered (Win) 1 07-07-2010 08:50 AM
Pro Tools M-Powered at 96khz: is it working properly? creator Pro Tools M-Powered (Win) 0 12-01-2007 11:44 AM
ProTools M-Powered quits when I try running at 96kHz. Help! funkbaby Pro Tools M-Powered (Mac) 0 04-11-2007 08:20 PM
projectmix + m-powered at 96kHz? delpinator Pro Tools M-Powered (Win) 6 10-26-2006 01:19 PM
M-Powered 6.8, FW Audiophile and 96kHz Session shorty909 Pro Tools M-Powered (Win) 0 03-13-2006 07:11 PM
