We recently installed the Mojo which now replaces my old Canopus DVAC (???) 100. With the Canopus the Video Sync Offset in Pro Tools was 22qf's. 1) I'm having some trouble figuring out what the "Offset" should be now that I'm using the Mojo. Any recommend methods maybe using a 2 beep? 2) Sometimes I get sent Quicktime files that I convert to DV (in order to play on my monitor).... and most times I'm pulling picture from a Digi Beta. Would the Offset be different for these two scenarios? 3) If the editor is on a Avid should I now have him create an export that also contains his video right from the Avid, since I have the Mojo? 4) Final Cut editors will still "have to" put picture to tape (as opposed to export something the Mojo can use), correct? ProTools 7.3.1, Mac 10.4.9, video recorded to an internal 2nd hard drive, monitoring video on an old school Panasonic tube TV & also a Phillips flat LCD. Thanks!
Thank you, SPC |
![]() Quote:
#1. See above post. #2. Yes. DV QTs and AVID QT OMFs will have a different offset. QT is in 1/4 frame increments, Avid is in 1 frame increments. If you get a Digi and load it via Mojo, then you will have an "Avid QT" video in your system. #3. Have the Avid editor export an OMF (2.0) of their session with NON-EMBEDDED media. Then use IMPORT SESSION DATA in PT to load picture and audio. This is by far the best solution over loading video. #4 FCP editors can export their pic using the free Avid codecs available from avid.com. It will still have a DV QT offset, but will work fine (and look pretty damn good too). |
![]() Quote:
Emf: Thank you much! That's the type of feedback I was looking for. Pirate: Thank you, too. You're a man of few words but a good link.
Thank you, SPC |
![]() Quote:
BUT: Depending on your codec you will need to eneter a different QT-offset. frank.
PTHDn 2021.3 (OSX10.14.6), 8x8x8, MacPro 5,1 3.33Ghz 12-Core, BM DeckLink SDI, SYNC HD, all genlocked via AJA GEN10, 48GB RAM, Xilica Neutrino, Meyersound Acheron |
Avid says to start at 14 quarter frames for mojo offset
If a avid editor exports a Avid .MXF file there is no need for a tape or digitize just import the MXf as a video file into protools For filal cut projects you can use mediastation to convert files to an avid file I dont touch the tape machines anymore especially HD there is a 2 frame forward offset required to layback to a HD deck in sync so its better to give the mixed audio back to the editor and have them layoff the video and audio together making it less likely to have sync drift between audio and video |
Only if your deck is not configured correctly.
Mojo Video Sync Offset | TAFF | Post - Surround - Video | 4 | 04-01-2011 11:42 AM |
Video sync offset | samplaire | Post - Surround - Video | 9 | 11-16-2010 05:50 AM |
Keeping Laybacks in Sync (delay compensation and Video sync offset) | edit machine | Pro Tools TDM Systems (Mac) | 6 | 11-15-2010 11:33 AM |
Video sync offset changes | Studio Studio | Pro Tools TDM Systems (Mac) | 0 | 09-15-2008 06:33 AM |
VIDEO SYNCH OFFSET (MOJO, SONY LCD) | Rick Sanchez | Post - Surround - Video | 7 | 05-24-2007 11:46 PM |
