Go Back   Avid Pro Audio Community > Other Products > Storage Subsystems
Old 01-17-2006, 06:25 PM
AVGuru1 AVGuru1 is offline
Default Mass Storage Cards Inside Expansion Chassis
Digi compato suggests that other PCI based cards can be used within their expansion chassis....even ones that need 3.3v and 5v. Assuming this is true....here are some limitation questions:
1. Does this include SCSI (namely ATTO UL4D, and upcoming UL5D) and/or Fibre Cards (ATTO 3300, for example, not Apple Fibre card, and it would be used for Unity)? If so, what slot in the chassis? I've seen SCSI being used, but not fibre.
2. If the chassis can support 3.3v and 5v, could you use a card which worked in a G4, but now will not work in a G5 due to the voltage change?
3. Are Firewire cards supported in the chassis as well? 400 & 800? USB?
Thanks Digi!
.: michael kammes mpse
.: post audio
.: applications editor / workflow consultant
.: michaelkammes.com
.: lucidsound.com
Using PCI cards in expansion chassis with a new PCI-e Mac? Mt.Everest Pro Tools TDM Systems (Mac) 7 03-04-2010 11:50 AM
UAD card in Expansion Chassis with Mix Cards Phenomental Pro Tools TDM Systems (Mac) 1 07-04-2006 07:16 AM
Will new pci expansion chassis work with mix cards Coz Pro Tools TDM Systems (Mac) 1 12-19-2005 11:09 AM
Non-TDM cards in expansion chassis? bigfrog General Discussion 0 01-03-2004 06:38 AM
5 volt cards with G5 in expansion chassis? Jeff Ulmer Pro Tools TDM Systems (Mac) 9 08-12-2003 09:37 AM
