Old 07-08-2008, 02:09 AM
ninja pro-tools ninja pro-tools is offline
Location: in your kitchen eating your food while you sleep!...currently ; )
Default 003r BROKEN MIC PRE\'s for input 3 & 4???? PLEASE help!!!!!
Man I'd be so appreciative if someone can help me with this....I am completely worried right now and scared I may be at a loss of money buying this thing used.
I just recently bought a Digi 003 rack off of Ebay, for like $800 bucks. Just got it a few days ago, and im basically testing all 4 mic pres to see if they work with my mic and XLR cable.
Now, when I plug the mic into the XLR input of mic pre 1 or 2 and talk into the mic...I get signal no problem.....but when I try inputs 3 and 4..........NOTHING! I get no signal at all man.......
I checked the I/O options and I have channel 3 routed to the input 3 of the interface. And channel 4 routed to input 4 of the interface.
I've tried to route output 3 and 4 to both channels 3 and 4, and then route output 1 and 2 to channels 3 and 4, but still nothing happens.....its as if these 3rd and 4th inputs are broken or damaged or something...im hoping no mannnn, im already in the process of sending back some defective Mackie speakers that way a ton to this bi*#* in florida......please someone try and help me out.
Would thi have anything to do with the amount of RAM I have on my PC? I also have dual processors, and I don't see how mic pre 1 and 2 can work, and not 3 and 4......
I will try to re-install the software, and post here again...hopefully it was a bug or something...but its very weird....im just hoing someone here has ran into the same problem and can help me out as sooon as possible, because my deadline to send this thing back in if its broken is on its way...
Old 07-08-2008, 06:53 AM
spkguitar's Avatar
Default Re: 003r BROKEN MIC PRE\'s for input 3 & 4???? PLEASE help!!!!!
What mic are you using? Does it require phantom power? I bet you have the phantom power switch turned on for channels 1&2 but turned off for 3&4.
Old 07-08-2008, 07:40 PM
Open the unit and look for a loose connector. I read something about a batch of these going out with a wire harness inside that was tied off too tight so the connector would come off either part way or completely. Simple fix is to cut the wire-tie that holds too much tension on the wires.
003r blinking = broken? fransmo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-03-2013 02:14 PM
Using Digi 003R as an Output Device for other programs...broken? RobbaDobba 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 03-21-2013 08:20 PM
003r + turntable + broken s/pdif = need your help brothers...pleeeeeeeease..... ninja pro-tools 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 23 07-30-2008 12:35 PM
003r BROKEN MIC PRE's for input 3 & 4???? PLEASE help!!!!! ninja pro-tools 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 07-26-2008 12:06 AM
003R - Only 4 mic pre's! JM11 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 13 12-14-2007 06:20 PM
