Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 04-10-2020, 02:13 AM
dobes dobes is offline
Default Pro tools hangs on close
Hey everyone,
I have a new surface pro 6 (Intel i7, 16Gb RAM, Windows Home 64bit), and have installed pro tools 2020.3 with their default plugins only.
I have a Zoom UAC-2 USB3.0 hardware interface that i have used on my previous surface with pro tools 10 with no issues.
When the interface is connected, it works fine in pro tools, however when i close the session or protools itself then it hangs and cannot be closed. I cant even close it via the task manager unless i turn off the Zoom device.
My assumption is that something is getting locked but i cannot figure out how to resolve the issue.
Things i have tried:
  • Ensuring pro tools runs as administrator
  • Setting windows to use internal sound card so pro tools can use the Zoom one
  • i've tried setting the Zoom sound device to allow to be locked by applications and not locked - no difference
  • Deleted pro tools preferences
If i run pro tools on ASIO4ALL then the problem is resovled and it closes fine without crashing - although can't actually get any sound out but thats a different problem.
If anyone has any more suggestions the it would be appreciated
Thanks
Old 04-10-2020, 07:19 AM
Default Re: Pro tools hangs on close
I have spent the last few hours trying numerous different configs and not getting anywhere.
To prevent the Zoom device being shared i have turned off system sounds so nothing should be using the device other than pro tools.
It still hangs on close, and cannot have the process killed unless i turn off the zoom device first.
weird and annoying.
Old 04-10-2020, 10:22 AM
DetroitT's Avatar
DetroitT DetroitT is offline
zoom drivers And firmware up to date?
Class compliant switch make a difference on off?
Bus powered or powered unit?
https://www.zoom.co.jp/products/audi...udio-converter
Old 04-11-2020, 04:24 PM
lesbrunn's Avatar
lesbrunn lesbrunn is offline
Originally Posted by dobes View Post
Hey everyone,
Thanks
I had a similar problem when I first installed 2020. I solved it by uninstalling, cleaning up and re-installing. I had previously just uninstalled 2019 and installed 2020, without cleaning the remnants of 2019.
MSI Pro Z790 Edge | i913900k @ 5.7GHz | 64GB DDR5 5600| 8TB NVMe | 3TB SATA SSD |10TB WD Black | Audient iD14 | PT 2022.12| Win 11 Pro | Tons of VIs and plugins
PT11 demo won't close - just hangs geegee Pro Tools 11 13 09-01-2014 08:53 AM
REX Shared AIR Library.dll Hangs Win 7 x64 on Close DFT Pro Tools 10 2 02-22-2013 09:39 PM
PT 7.4 cs5 OSx 10.4.11 Protools hangs on session close xxicjoy Pro Tools TDM Systems (Mac) 1 02-25-2009 01:08 PM
pro tools open and after a second they close extratone Pro Tools M-Powered (Win) 5 11-20-2006 02:18 PM
Protools free hangs when i close app hat123 Digidesign Hardware & Software 3 07-19-2001 05:10 AM
