2 mbox probs: mix control switch + latency, help!
Here's my system:
ibook G4, 1.33GHz, 768 mbRam, PT 6.7, OS 10.3.5 I'm putting down vocals over some basic tracks. BEFORE I record-enable the track, My mix control switch seems to work, that is, when I turn it to the left (input) i hear my mike, when I turn it to the right I hear nothing. When I record enable the track and hit play, i have two problems. Latency, I assume, is causing an annoying vocal delay effect. Hoping I can remedy this using the mix control (ie. hear less or none of my vocal as I record it) I find that it doesn't work. The input is heard at the same level no matter which position the switch is at. This also happens when I use the mono button. Has anyone experienced this problem? Thanks, Paul ibook G4, 1.33GHz, 768 mbRam, PT 6.7, OS 10.3.5
ibook G4, 1.33 GHZ, 768 MBRam, Pro tools 6.7, MBOX, OS 10.3.5 |
Re: 2 mbox probs: mix control switch + latency, help!
You need to mute the track you are recording to, then use the mix knob to balance the levels of previously recorded tracks (and/or click) with the input to the muted record-enabled track.
thank you very much. i will try this right away!
-paul
also, it helps to engage the MONO button which puts the direct signal (what you are recording- in this case vocals) in the center instead of on the left.
thanks!
2 probs - adat clock and low latency | stevesound | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 08-31-2005 10:45 AM |
Switch Mac Mbox to Windows - and then switch back | bluesigns | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 05-07-2004 09:50 AM |
latency probs. | Antti Turpeinen | Digidesign Hardware & Software | 7 | 05-11-2001 12:06 AM |
Digidesign Control Panel probs.. | Sound Works UK | Pro Tools TDM Systems (Mac) | 5 | 04-22-2001 02:18 PM |
Pro Control with Hub and Switch | Wellnitz | ProControl, Control|24, Command|8 | 0 | 05-20-2000 02:40 AM |
