Old 03-10-2005, 02:47 PM
MR808 MR808 is offline
Default Midi I/O shows up when it want to
Midi I/O shows up when it want to, I have to reinstall midi drivers from the 6.7 cdrom, and then it will show in the midi beat clock page but when I reboot its not showing the 002 midi ports so I try to re install and it states that I already have it install, so I then uninstall and reinstall and the same thang happens again, but if I open a session that previously showed the midi ports, I can continue to create new session and the 002 midi ports show. But if i exit protools and relaunch and creat a new session I have to uninsstall midi drivers and reinstall. ????
Any suggestions
Old 03-10-2005, 04:48 PM
Default Re: Midi I/O shows up when it want to
Sounds to me like you've reached the XP 10 MIDI device bug/issue... search the DUC for the link to the RME web site which describes how to clean out the registry.
To diminish the issue always plug the MIDI I/O into the same USB port every time.
RME Link
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 03-12-2005, 12:28 PM
Im not using usb for the midi I use the 002 only when using PT6.7 and i use the RME HDSP when I use Nuendo 2.1
Old 03-12-2005, 02:38 PM
I thought you said you had a "MIDI I/O".
You should still check the registry if you don't have the latest cs update of 6.7 installed.
Rail
Platinum Samples
pro tools midi input shows no channels activated lexaudio MIDI 0 09-19-2013 10:51 AM
Audio MIDI set up shows Ghost Interface-WTF Groovacious macOS 1 07-06-2012 12:24 PM
MIDI Data Shows But Won't Play Back MusicalFlairs macOS 3 03-31-2012 08:57 AM
Digi 002r MIDI I/O shows "(No Channels Activated)" Stephen Bond 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 09-05-2003 01:40 AM
MIDI drums shows in volume LED, but nothing in monitor... Bodhisan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 07-16-2003 10:05 PM
