Control 24 Fader 9-16 stuck at max + +
Hi
1st post, and already asking for help..... I bought a 2nd hand Control 24 the other day, with known defects. Got it cheap I´m trying to find the problem, but need som advice and help. Hope some1 can get help me.. On power on, the faders clicks, and fader 9-16 immediate goes to the top, the rest resets to lowest position. When offline, faders 9-16 allways returns to top if manually forcing them to any other positions. The "Scribble strips" is not showing any info, neither does the ch select button light up. I´ve checked the 3pin connector in the psu. Pressing utility works, but I cannot read any info, thus not possible to run any diagnostics. Diode D5 in the cub board blinks. Anyone have any info on these diodes? there are 4 diodes on the cub board, I guess this is a diagnostics for the status of these leds... I can connect to protools and use many of the features, transport, faders 1-8 + 17-14 (some faders are a bit "nervous") The analogue section seem to work (not tested audio....ad I don´t plan to use audio through the console) I´ve replaced C20 on the power supply, and measured all voltages (tho not under load) EDIT: All voltages are correct when the unit is on. No voltage drops, so I guess the psu is ok... The previos owner told me that a tech told him he had to replace 1 of three boards,,,,, I´m not sure what board this could be..... Best regards Ole Peder, Norway |
Re: Control 24 Fader 9-16 stuck at max + +
The whole board is cabled together with ribbon cables and push connections and they can easily come lose or not connect well. I did a post re fixing jumping faders a while back which will give you an idea of how to clean and check all cables and connections etc. and also give the power supply a good clean on the connections. If the power supply is a Skynet one you can send it to skynet for a service/fix for reasonable $$$ I guess its a fader board you need. there are 3 boards One for each bank of 8 faders etc. my previous post for reference... http://duc.avid.com/showthread.php?t=322252 Chris
The faders are supposed to click , this is normal.
Because you are having issues with the entire strip it is not the fader I would imagine. but if the rest work well I would expect your problem to be near the input of either the power or the digital info being sent through . Since it is not showing any info at all for either it is before the scribble strip and or fader . Reseating click plugs fixed a issue for me give it a try. |
Thanks for the replies.
I´ve checked all the connections quite a few times.... As there are 3 boards for the scribble strips, and none shows any info,,,, My immediate thought goes to the controller. In my mind that is the CUB board... is it? I´ve contacted Avid through a local dealer, to hopefully get spare parts.... If i.e. you have a badly connected dc plug to one of the internatl boards, and gently tap it with a "insulated tool", and the power is again going to the board,,,, will the board immediately "work" og do I need to shut down the unit to get it properly started? (pardon my english,,,, I tried to explain as good as I can...) Brgds Ole Peder |
fader stuck and midi lag | DAPianist | Pro Tools 10 | 4 | 06-24-2013 07:34 PM |
Send fader stuck | smpkeys | Pro Tools TDM Systems (Mac) | 5 | 03-25-2010 10:24 PM |
Stuck 002 fader problem | Lexvortex | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 08-12-2006 05:01 AM |
C24 Stuck Fader | Greene | Pro Tools TDM Systems (Mac) | 2 | 08-04-2003 09:00 AM |
Stuck fader | Greene | ICON & C|24 | 0 | 08-02-2003 08:11 PM |
