Go Back   Avid Pro Audio Community > Other Products > Storage Subsystems
Old 06-11-2009, 12:12 PM
acktopus acktopus is offline
Default Firewire External HD will this work?
Wow, this is quite a painful learning process! I just recently upgraded to a new laptop and PT 8 with an Mbox Mini and have decided to get an external firewire drive for audio files. I've done a lot of reading in the forums and have checked the firewire requirements that Digi recommends but sadly some of the drives (Glyph etc) are just a little out of my price range.
I found this recommended by someone in another thread:
http://www.storagedepot.co.uk/Hard-D...c884/p536.aspx
As this enclosure contains an Oxford chip I assume it will be fine to use with my Firewire 400 port but what should I be looking for when I buy a hard drive for it?
I know that it needs to be a 3.5" SATA, 7200RPM and with a seek time of under 9ms (I think!) but are there specific, reliable makes that people would recommend or does it not really matter?
It seems that this is a bus powered, fanless enclosure but are there any reasons I should maybe go for an ac powered one with a fan?
Anything else to bear in mind?
I'm not really a technical person and the whole external thing is quite new to me. I've only ever used a USB Western Digital external in the past for general backup and didn't realise the subject could get so complicated!
Old 07-06-2009, 05:33 PM
JazzyJ JazzyJ is offline
Default Re: Firewire External HD will this work?
If it's got the Oxford chipset it should be fine.
Also, Oyen Digital sell 2.5' Firewire Drives that are 7,200RPM
http://oyendigital.com/firewire-usb-...ard-drive.html
The prices are not bad.
I used this one:
http://oyendigital.com/firewire-hard-drive.html
with a 7,200 RPM Hitachi Drive in it and recorded an album in the north of Brazil which was well hot. The drive is not fan assisted and was totally fine.
Why does Avid recommend external USB over external Firewire for audio drive? DJ Hellfire Pro Tools 10 10 03-29-2012 09:39 PM
Are external HD FireWire 800 approved to work with PT ? Chris7514 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-04-2007 08:49 PM
Making an External Firewire drive work on both MAC & PC??? JLEpperson Pro Tools TDM Systems (Mac) 4 03-13-2007 07:01 PM
Firewire Solo and Firewire External Drive TrevorForrest Pro Tools M-Powered (Win) 6 04-28-2006 02:59 PM
How can you use an external firewire drive and Digi002 with only 1 firewire port? CraigD 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 07-16-2003 01:11 AM
