Old 12-04-2017, 06:10 AM
anotherfilip anotherfilip is offline
Default Avid Omni - Digital I/O does not engage after changing in Hardware Setup
Not sure if I'm missing something here but when I change my settings from analogue inputs/outputs to digital the changes aren't reflected in the session i/o. They remain stuck on the analogue settings. I have had this working fine in the past with the same system but for some reason it is no longer responding. I have attached screenshots of setup and I/O windows. Would appreciate any help!
Old 12-09-2017, 07:27 PM
BScout BScout is offline
Default Re: Avid Omni - Digital I/O does not engage after changing in Hardware Setup
What happens if you click on the channels in the I/O setup and flip the settings there? Does it work like it should (and you see all the options)?
Old 12-11-2017, 04:26 AM
Thanks for your reply. I did try that yes, as well as everything I could think of but still no joy. I have been on 12.4 for a while after the new PT licence kicked in and I didn't upgrade. I'm guessing that due to no upgrades in my system for a while something had paralysed this function as well as a couple of other strange anomalies starting to creep in. I had tried fresh installs but still no joy. I was putting off the upgrade but did need to do it at some point anyway so upgraded my HD system and all working again!
how to get 4 x hardware inserts with AVID OMNI / PT HD outoftune Pro Tools HDX & HD Native Systems (Mac) 7 04-04-2014 08:53 AM
Using a Distressor as a hardware insert with Avid Omni & ProTools 11 HDX agrizzlybear Third Party Interfaces 8 03-20-2014 12:10 PM
Audio Midi Setup doesn't recognize io on Avid HD Omni Thunderbolt MJarzabek Pro Tools HDX & HD Native Systems (Mac) 5 10-10-2013 07:36 AM
how to setup hardware compressor and eq to HD OMNI CDac Pro Tools HDX & HD Native Systems (Win) 3 07-03-2012 06:58 PM
pulling my hair out! i/o and hardware setup keep changing. regis Pro Tools TDM Systems (Mac) 6 06-09-2008 10:06 AM
