Bounce skips the first milliseconds
Anyone else?
I'm on 2019.6 and High Sierra. I have no red fields in the dly comp. Dly comp enabled. Audio track is passed through 2 aux busses which I suspect is the cause, but I consider it a bug. A bounce shouldn't exclude anything , unless plugins exceed the maximum dly compensation allowed. How about the duc got PT for free...we're all just helpful beta testers.. |
Re: Bounce skips the first milliseconds
Just bounced out a whole album’s worth of stems, no issues. Screenshot or some sort of description of exactly what you’re doing might help.
Are you highlighting PRECISELY what you want to bounce, and not just bouncing the whole window? Leave a few blank seconds at the beginning of every session, highlight what you want to bounce (zoom in, hold the SHIFT key and you can fine-tune the start point.) if you’re in the habit of slamming everything all the way to the left, yeah, it’ll clip the start of the first note. It doesn’t matter where on the timeline the session starts if you do it this way, and you won’t clip off the first couple of milliseconds of the first note.
This is typically caused by a plug-in.
Bob's room 615 562-4346 Interview Artists are the gatekeepers of truth! - Paul Robeson |
Some plugins don't report the proper delays (PSP's Vintage Warmer was a culprit for years). Which plugs are on those two Aux tracks?
Mondo Mod is another one that is completely wrong 👍
Thanks for your replies!
I found the bugger... It's AGAIN sonarworks reference.. Put in last on the masters fader, bypass, bounce.. you loose some.. you win none.. |
I always inactivate Sonarworks before bouncing. Also, on my HDX system, if you have the reminder to bypass it enabled, it makes the bounce delay commencement quite a bit on my system.
Neale Eckstein Fox Run Studio website Fox Run Studio Youtube Channel Neale's photography website |
SW Bug? |
Well for troubleshooting purposes, deactivate (not bypass) all plugins everywhere and have a bounce, just to check if everything is there. If nothing is missing, you know one of the plugins is causing the trouble so activate one plugin brand a time and re-bounce. After a while you will know which plugin it is.
are 3 milliseconds of latency noticeable? | jcche19 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 11-25-2010 04:23 AM |
Music Skips During Bounce to Disk | Superbee | Pro Tools TDM Systems (Mac) | 9 | 04-13-2007 04:38 AM |
Music Skips During Bounce to Disk | Superbee | Pro Tools TDM Systems (Mac) | 0 | 04-05-2007 09:22 PM |
Milliseconds????? | Peter Groom | Pro Tools TDM Systems (Mac) | 2 | 02-09-2007 06:14 AM |
skips after bounce | aleeleota | Digidesign Hardware & Software | 6 | 06-07-2003 01:31 PM |
