Pro Tools 10.2 crash Kontakt 5 player Mountain Lion
I recently updated to Mountain Lion and everything seems to be working fine except the Kontakt 5 player plugin.
The standalone Kontakt 5 player works fine but Pro Tools crashes the moment I load the plugin but it was working fine on OSX 10.7 Anyone has it running or what I can do besides waiting for patches/updates? |
Have you tried reinstalling K5?
A Rig: MacBook Pro Spring 2013, 2.8Ghz I7, 16GB RAM, OSX Mavericks 10.9.4, PT 11.2, MBox Pro 3, Glyph GT 050 Qx3 1.5 TB drives Thunderbolt-FW400, Presonus Faderport. 10 REMOVED! B Rig:MacBook Pro Spring 11, 2.33 GHz I7, 16GB RAM, OSX Mavericks 10.9.4, PT 11.2, MBox Pro 3, Glyph Portagig 62 portable 1 TB drive Firewired with 400, Presonus Faderport. 10 REMOVED! I am the main songwriter/performer for Midwest Whitetail, Cabela's Deer Nation, Spring Thunder, and Northern Waters Series! |
Re: Pro Tools 10.2 crash Kontakt 5 player Mountain Lion
Reinstalling doesn't fix it, still crashing.
Fixed:
Deleting the standalone application of Kontakt fixes the problem. (Unless you need them both as rtas and standalone of course) |
That's a bummer. I will be away from the studio for a week but I will ask around. I am holding off on ML for the reasons folks ate having! U may need to do the usual delete press, etc. I will check with Kontakt in the meantime.
Awesome. I am glad u got that figured out. Do u notice a big difference in ML?
Just FYI, what it appears to me to be is a problem with Kontakt Memory Server. If I have it set on the plugin version of Kontakt, 10.2 won't launch, will quit out. Solution is to delete the com.nativeinstruments.com.Kontakt pref file (whatever it's called) from your user folder. PT launches fine after that, and just don't turn on the memory server.
Had to set it off in the stand alone as well, maybe that's why deleting the stand alone worked. But for anyone else, try just deleting the pref file, and relaunch. PT and Kontakt should work as long as you don't turn on the memory server. That seems to be where the errors lie, at least for me! Otherwise, 10.2 and 10.8 are getting along fine together here. |
for the memory sever? |
but it still results in a crash in pro tools. Quote:
Pro tools 10 & mountain lion | Mr.J | Pro Tools 10 | 1 | 08-31-2013 04:01 AM |
Pro Tools LE 8.0.5.1 & Mountain Lion | plin | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 06-30-2013 02:34 AM |
Impossible to start Pro Tools on MacPro after downgrade Mountain Lion back to LION | DESVED | Pro Tools HDX & HD Native Systems (Mac) | 2 | 05-21-2013 03:18 PM |
Pro Tools 10.3, Mountain Lion, and SSD | nathanholliday | macOS | 3 | 10-03-2012 01:07 PM |
Pro Tools 8.0.5 Mountain Lion Mac 10.8 | madballa | Post - Surround - Video | 1 | 09-30-2012 05:10 PM |
