Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools | First Discussion
Old 06-23-2015, 03:25 PM
hatusage hatusage is offline
Default Pro tools First hanging on startup
Pro tools is hanging on 'Initializing audio engine'. Then it says 'Choose another engine', but you can't because all options are greyed out and when you try anything else it shuts down.
Any help on this would be appreciated. Might be because I'm running the Windows 10 preview?
Thanks
Old 06-24-2015, 02:54 AM
junkgear's Avatar
junkgear junkgear is offline
Default Re: Pro tools First hanging on starup
Thanks
Could be anything with a preview release of an OS.
If you really want to give it a go, I would try PT First on a supported OS.
Also, what audio interface is connected to the PC or are you using the internal sound?
Will K
System Details
Old 06-24-2015, 07:01 AM
DigiTechSupt's Avatar
Hi hatusage,
Unfortunately, Pro tools|First is still unsupported on Windows 10. Most probably the reason why you are getting errors launching it.
BTW. Pro tools|First has it's own support forum page. Click here to visit.
Best Regards,
YD
Avid Audio Tech Support
Support FAQ
Old 06-25-2015, 05:32 PM
Thanks all... guess I'll just repartition and install 8.1
Old 07-09-2015, 01:02 PM
Guitarmike12 Guitarmike12 is offline
Hello. I just installed PT first. I am running A PC Windows 8.1 --8 GB ram--64 bit OS
I was able to install and it appears all updates are installed in Avid manager. When I open PT it loads and brings me to use template or create new. I click on template and it hangs.
I reinstalled and still the same issue. Any help?
Thx
Old 07-09-2015, 01:25 PM
Hi Guitarmike12,
Did you already downloaded and installed Xpand!? If not you may download the installer in Marketplace right inside Pro tools|First.
Best Regards,
YD
Support FAQ
Old 07-09-2015, 05:15 PM
Hello. Here is the message I get When running PT.
no jvm could be found on your system please define EXE4J_JAVA_HOME to point to an installed 32-bit JDK or JRE or download a JRE from www.java.com
Old 12-19-2015, 03:10 PM
mvanstee mvanstee is offline
I have had the same problem since I downloaded this months ago. Good ting I have several other competing DAWs but I really want to try Pro Tools. Anyone find the fix?
Old 12-24-2015, 05:38 AM
Default Re: Pro tools First hanging on startup
Hello mvanstee,
Could you post screenshots of the error message. What are your computer details.
Regards,
RC
Support FAQ
PT 12 hanging on startup. mikegav_in Pro Tools 12 1 05-13-2015 03:31 AM
Pro Tools 11/10 hanging on startup, crashing Mac Pro :( spmusik Pro Tools 11 4 07-19-2013 05:19 PM
Pro Tools LE 8 hanging on startup with VocalignLE - WIN 7 RC otobot 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 11-01-2009 12:32 PM
Pro Tools LE 7.4 hanging on startup vlepore VENUE Live Sound Systems 1 10-11-2009 01:31 PM
Pro Tools hanging on startup at "Loading Plugins" Eric Gale 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 07-03-2006 06:35 AM
