A couple beginner questions
Hey everyone,
I apologize for this novice nature of this question but I have been wasting a lot of time trying to figure it out and I am getting nowhere. I recorded a 2 hour set from a band. Say I want to strip out just one song from that set to work on. I have already separated that song as its own region and I stripped out the rest of the music. Pro Tools still seems to think that the session is 2 hours long. Is there a way to tell it that this session is now only 4 minutes long? The other problem, and a bigger one, and maybe it's related, is that with the selector tool I can't select a specific spot within the waveform. The selector tool only falls on 1 second intervals but I need to select spaces between the seconds to pinpoint what I need to edit. I didn't have this problem last time I edited a song so I assume it's just a setting but I have no idea what. Thanks for the help Pro Tools 11 MacBook Pro |
Re: A couple beginner questions
Question 1: I'm guessing that when you say PT thinks the session is 4 hours long, you mean that the 4 minute song (region) you isolated is like 4 hours down the edit window grid. If that's the case, you should be able to just grab the region and slide it down to the beginning of the edit window grid. You can grab the region with the grabber tool. It's at the top of the edit window and looks like a hand.
Question 2: You're in "grid" edit mode, which makes your cursor skip certain intervals in the edit window. Look in your upper left hand corner, and you should see 4 boxes that say "shuffle", "slip", "spot", and "grid". See attachment for pic. Click "slip." This stands for slip edit mode. It let's you click on those spots in between you're trying to get to. Hope I've helped.
PT: 10 OS: Windows 10 Audio interface: Behringer Xenyx Q802USB CPU: Raptor Z55 SKYLAKE by Velocity Micro Processor: Intel Core i7-6700K, 4-core @ 4.0 GHz DDR4 Memory: 32 GB Crucial Ballistix DDR4-2400 MHz (4 x 8GB) Hard Drive 1: 525 GB Crucial MX300 Solid State Drive Hard Drive 2: 3TB 7200rpm SATA 600 with 64MB Cache |
here's that attachment.
Thanks for the info on the edit modes. Had no idea what those were for. |
Did you "Hide" the unwanted recording? Or did you delete it?
If the region is still in the playlist, then PT will assume that the session is as long as that clip. |
I did delete the unused portion of the session
It's been a while, but IIRC I did a "split" on every track right where I wanted the song to end, then deleted the parts I didn't want.
This reset the "session" length to the actual length of the song. I think I did this in Pro Tools, but if not, you got a free Cubase or Reaper tip!
X Note that all opinions, observations, whatever, in this post are mine, unless I'm being mean or am wrong, in which case it's somebody else's fault. I do not work for Avid (their loss)...my only relationship with Avid is that of a customer (when I'm not too poor to buy stuff, like now)...and that hot administrative assistant...that's more of a "thing" than a "relationship" (that should keep them guessing for a while...) Just rockin'...what more is there? Bill in Pittsburgh |
Depending on what version of Pro Tools you're using, you could have left automation edit points "out there" where stuff once was, or when you made the cut.
Select the whole session to display (Alt+A) and then go through the automation lanes and see if something's out there.
WombatStudio.Org • Digital Recording, Mixing and Mastering in Gibbsboro, NJ • USA "It's not the gear ... it's the ear" |
At least I hope it's as simple as that... |
Some Beginner's Questions | Petexxx | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 03-06-2010 10:30 PM |
Some Beginner Questions | andrewkstone | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 08-21-2006 02:51 PM |
Some Beginner Questions | andrewkstone | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 08-21-2006 08:29 AM |
a few beginner questions | Devan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 22 | 07-13-2005 11:30 PM |
A couple of beginner questions for an extreme noob | Mandarax | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 10-03-2004 07:59 AM |
