Old 05-03-2010, 01:06 AM
peter99 peter99 is offline
Default How much RAM is enough?
I'm mainly mixing big sessions with lots of plugins and some VI's - how much RAM do you recommend to buy? I have a dual quad 2.8 mac pro with PT 8.0.3 on OS 10.6.2
at the moment I have 2 1MB chips and 2 2 MB chips total 6MB ram
just wondering what you use
Old 05-03-2010, 01:43 AM
chrisdee's Avatar
chrisdee chrisdee is offline
Default Re: How much RAM is enough?
It depends on what plugins and vi's you are running. If you for example take Trilian, some of the samples/instruments are 3GB. Personally, I'v got 6GB running W7 64bit ultimate and PT 8.0.3cs2. I'm not able to run Trilian smoothly on my I7 setup. Neither am I able to run Strike smoothly. But the other plugins and VI that comes with PT8 runs fine with 6GB ram.
Old 05-03-2010, 02:23 AM
tamasdragon tamasdragon is offline
Yes, with vi's the more the better.
my blog:Tamas Dragon
Old 05-03-2010, 08:45 AM
docscholl docscholl is offline
Been thinking about buying this.
Is it a RAM hog?
003+ Factory & Mbox 3
Apple powered by OS X 10.5.8:
iMac 2GHz Intel Core 2 Duo/4GB SDRAM (8.0.5LE)
PreSonus DigiMAX FS
Old 05-03-2010, 11:10 AM
emorganproductions emorganproductions is offline
I use strike all the time, sometimes multiple instances, with a 4GB ram 2007 macbook pro. 6 GB should be more then enough
Evan
Click me...
MacBook Pro 2.5 GHz intel i7, 16GB / OSX 10.7.2 / PT 9.0.6 / 003 Factory
Old 05-03-2010, 11:38 AM
huzzam huzzam is offline
640K ought to be enough for anybody.
--Bill Gates, 1981
(ok it's apocryphal)
