  #2401
Old 02-21-2011, 04:15 AM
tamasdragon tamasdragon is offline
Default Re: Best Core 2 Series Desktops-Results and Specs
Next time I read before post....
my blog:Tamas Dragon
  #2402
Old 02-23-2011, 10:07 PM
TOM@METRO's Avatar
Originally Posted by omad 001 View Post
also should have mentioned i planned to double my ram so that is def in the pipeline aswell
Cheers to all
Be sure to match the RAM exactly. Brand speed timings... everything.
~ tom thomas
Formerly hobotom
Pro Tools Ultimate 2019.5 HDX
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
  #2403
Old 03-07-2011, 03:25 PM
blizzard blizzard is offline
Hey Peeps...
So I am going to be upgrading both of my machines to WIN7 (from XP and Vista64). Now that I will have more RAM available to me because of 64bit, I am looking to get some more.
My question is does anyone know where I can find 4GB sticks of DDR2 RAM online? Preferably in Canada so I can avoid import tax. I am having a hard time actually finding any...
Also, has anyone safely veered from the Qualified Vendor List for their machines and been successful?
Thanks for the advice!
DAW - Asus P9X79 / 32GB / i7-4820K / WIN7 PRO / VEPRO 5
PT 11.3.0 / Blacklion 003R / Microclock
Macbook Pro Retina / 2.8GHZ / 512GB SSD / PT 12.4
  #2404
Old 03-19-2011, 01:28 AM
TOM@METRO's Avatar
A lot of us here just go to Newegg.
~ tom thomas
Formerly hobotom
Windows 10
Intel Hexcore i7
  #2405
Old 05-22-2011, 12:13 PM
Obe1 Obe1 is offline
I've been meaning to try this D-Verb test thing for a while so I gave it a shot. I did the 2.0 test, but since I can only record through so many tracks at a time, I had to start using the second set of inserts to add more D-Verbs. In case I'm not being clear, 17 of my 46 record enabled tracks had 10 D-verbs on them a piece. Is that deviating from the test? I remember reading about the first D-Verb test and it said to add aux tracks, but it didn't say anything about that in the 2.0 test.
Anyway, I didn't change my buffer settings either because the instructions didn't say to. I was on 2048, and 85% cpu usage limit. Is that wrong? I ended up being able to record 317 D-Verbs for 5 min without the test tone breaking up. Actually, after 317 the computer just straight up wouldn't let me start recording, said too much CPU usage.
I have a 17-930 machine, OC'd at 3.52 or something like that, 6gb corsair ddr 3 ram, x58-ud3r mobo, 3xWD black 640 g HD's (64 mb cache) on PT 8 and Win 7 64 bit. Are those good D-verb results??
  #2406
Old 05-23-2011, 05:48 AM
mano111 mano111 is offline
Thats good results, well within what you can expect from your rig.
AFAIK the test shoud be done using the first 5 inserts only per track and run the test @ both 1024 and 64 buffers.
Its better to post the scores and your build specs on the i7 thread. The core2 thread is practically irrelevant considering the hardware that is available these days.
i7 2600K @ 4.4GHZ -- Intel DP67BG B3 -- 8GB DDR3 1600 -- Crucial SSD
PTLE 8.0.4cs2 -- DIGI 003R -- DV toolkit -- Waves 9
  #2407
Old 11-29-2011, 09:31 PM
AudibleE AudibleE is offline
I have a pretty specific question and after searching the forums I can't find anything exactly. I first posted in the Mac forum, oops... but hopefully someone might help.
My ASUS P5N E SLI, I think is not right with my build. Not stable and crashing. I'd like to just swap out my motherboard with something that is stable and supported by Digi.
Seeing my current build, would an ASUS P5B be a good solution?
Currently:
XP Pro SP3
Intel Core 2 Duo E6850
ASUS P5N E SLI LGA 775 NVidia nForce SLI ATX Intel board
EVGA 256 -2-N751TR GeForce 8600 PCI Express SLI
4GB Ram
2 SATA Drives: 1-60gb running apps, 1-500gb storing audio files and samples
Digi MBox 2 (USB)
Software:
PT 8.0 LE (also tried updating to 8.0.3 and 8.0.5)
Toontrack Superior 2.0
PodFarm
Amplitube2, Hendrix and Metal
  #2408
Old 12-01-2011, 08:08 AM
C'mon... help a brother out. No response? Comments? Nothing? BOOO!
  #2409
Old 12-01-2011, 09:20 AM
daeron80 daeron80 is offline
All the attention is on 9 and 10 these days, I guess.
Probably, if you can find one. The chipset is better known to be compatible.
David J. Finnamore
Nyquist was right.
PT 2019.6 Ultimate | Omni | macOS Sierra
PT 2019.6 | Saffire Pro 40 | Win10
  #2410
Old 12-01-2011, 11:18 AM
albee1952 albee1952 is online now
Currently:
XP Pro SP3
4GB Ram
Digi MBox 2 (USB)
Software:
PodFarm
DO NOT MIX nVidia chipsets with intel cpu's. Its a recipe for failure
i7 Builds - Specs and Results mykhal c Windows 6779 07-04-2019 03:26 PM
Intel Quad Core vs. i-series solidwalnut 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 11-23-2010 05:16 AM
Have a Quad Core (Asus P5K). Use Only One Core Active For Best Results? MIDI Issues. epu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 08-12-2009 02:24 AM
are these specs ok? (low budget 2 core) korkman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 08-22-2008 02:44 AM
8 Core Mac Pro, Leopard and Windows results pasanta 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 01-13-2008 06:51 PM
