Old 08-02-2006, 06:25 PM
elv1s1sal1ve elv1s1sal1ve is offline
Default Editing questions
I'm missing a couple of concepts in my research through my books, manuals and video tutorial. I am working with a session that includes both MIDI and audio regions. Her are my questions:
1) Is there a way to clear an entire passage of all tracks and have the passage after the clear automatically snap to the end of the passage prior to the clear?
2) Is there a way to grab multiple tracks and move them together if I highlight them?
3) Will converting MIDI tracks to audio tracks benefit me from a CPU perspective, and if so, what is the most efficient method to do this?
Thanks.
Gateway 7510GX, AMD Athlon 64 3700+ 2.39 GHz, Windows XP Pro, PTLE 7.3.1.123, MBox, 1 GB RAM, external Seagate 150 GB HD
Old 08-02-2006, 06:45 PM
Kryst Kryst is offline
Default Re: Editing questions
I'm not sure what number 1 means, and I don't work with Midi, but...
Yes.... highlight the tracks you want to move and move them. Simple.
Broken down? Ok. Highlight a track, Hold down Shift, click (or double click) another track (double click highlight's that full track.) Repeat with each track you want. Then set your mouse to Grabber and move them.... brilliance, I know.
Kryst
Old 08-02-2006, 07:00 PM
spkguitar's Avatar
#1: You're looking to put Pro Tools into "Shuffle" edit mode. Covered briefly on page 246 of the Reference Guide (and elsewhere).
Old 08-02-2006, 07:04 PM
Well, let me clarify a bit. I understand how to move individual tracks. That's not my question. I am working with 24 tracks that I need to move TOGETHER to save time. I attempted to highlight all the tracks I wanted to move and use the grabber tool, but it didn't work. Maybe the fact that it's a mix of MIDI and audio is causing the issue?
Old 08-02-2006, 07:06 PM
Ohhhh, well specify, man! Again, I don't work with MIDI, so now I wouldn't know if that's why you can't move them all back.
Kryst
Old 08-02-2006, 08:09 PM
Kurdt Kurdt is offline
[QUOTE]
You should be able to move both audio and midi regions together. If they are all the same selection time and length, using the time grabber should do the trick. If selecting different regions on different tracks at different times and not wanting to select the time in between those regions, try the Object Grabber.
It should work...
Old 08-03-2006, 06:33 AM
Camilo Toledo Camilo Toledo is offline
Honestly man, Elvis is alive but in another dimention.
As for number 3.
Yes, you will benefit greatly from converting midi tracks to audio tracks, only if you don't have one of those super fast, 64 bit X2, 4800 mhz, 2gb ram computers that can handle a heavy CPU load.
Why, simply because you can BTD each midi track to audio already as you want it, thus avoiding using plug ins and your CPU hungry virtual synths.
Camilo Toledo
Old 08-03-2006, 07:11 PM
THAT's what I was trying to remember. Thanks spkguitar! I kept thinking slip mode for some reason. Guess I was up too late and my brain a little fuzzy.
Old 08-08-2006, 07:27 AM
As for number 3.
Is there a quick, more efficient way other than just recording a MIDI track to a new audio track in realtime?
Old 08-08-2006, 07:29 AM
spkguitar's Avatar
No.
Two editing questions about PT 10 Jurek macOS 6 01-02-2012 07:48 AM
Two Editing Questions.... 100grit 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 12-19-2005 10:32 PM
editing questions sauna-l Tips & Tricks 4 03-19-2004 07:09 PM
Editing Questions Chris Coleman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 04-23-2003 12:14 AM
Editing Questions... Prophetico 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 03-13-2002 05:51 PM
