  #121
Old 11-15-2009, 08:49 PM
CplusE2 CplusE2 is offline
Default Re: Help Slaving Logic Studio to Pro Tools
Thank you again for making it clear to me. I know it seem like your repeating yourself.. Just wanted to say thank you...
  #122
Old 11-17-2009, 10:02 PM
Rockman413 Rockman413 is offline
Everything is fine to me. But when I turned on 'transmit MMC" in logic and sync, I can't play in logic!Help!
  #123
Old 11-18-2009, 10:22 AM
DigiTechSupt's Avatar
DigiTechSupt DigiTechSupt is online now
This is not enough info to be able to help you. You need to give us details about the exact steps you're using and the results you're seeing. Saying 'I can't play in Logic' doesn't mean much.
Are you using my or docrics instructions or mine? How do you have everything configured? The details are important, as they will help us identify where things are going wrong.
Avid Audio Tech Support
Support FAQ
  #124
Old 11-18-2009, 10:56 PM
Mark Ziebarth Mark Ziebarth is offline
If you put on the sync button in the Logic transport section it waits for MTC, you can't hit "play" then. There is an alternative setting in the logic sync options called "automatic". If activated Logic detects incoming MTC automatically but the transport section can be used for Logic only playback as well. Was that your problem?
Kind regards
Mark
Mac Pro 2010 3.66 GHz six Cores, HD Native, 192 I/O, Avid Dock, Artist Mix and Pro Tools Ultimate
Mac Pro 2008, RME Fireface, Pro Tools 12, Euphonix MC Control
  #125
Old 05-08-2014, 08:35 AM
HSLand HSLand is offline
This is a pretty old thread but it's got good info in it.
I'm using the IAC buss to sync Logic to PT. If I'm slaving Logic to PT via MTC and MMC, and I want to use Logic for midi strictly, will I still need to enable an audio driver in Logic so it can keep time and prevent drifting?
Earlier in the thread someone said after the MTC message, wordclock takes over and is what actually keeps a stable playback time. I've got all audio drivers in Logic disabled, but if I need to to get a more accurate sync and playback speed, I will.
So far I've discovered that I need to leave a bar in the beginning of the sequence so the MTC sync can play catch up. Even so, Logic is still behind by a very small amount as mentioned earlier. I guess I can make that up in the Logic settings.
Pro Tools 8 le, logic pro 9 and studio one pro barry1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-05-2010 05:38 AM
Logic Studio taking files to pro tools studio. smoochdaddy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 12-30-2009 10:55 AM
Pro Tools LE after Logic Studio PT fan002 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 09-25-2007 04:44 PM
Slaving Logic off Pro tools through rewire Paul Maunder 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-07-2004 10:37 AM
I invite Pro Tools users to use ProControl studio but most of them use Logic????????? Jules ProControl, Control|24, Command|8 37 12-07-2000 12:10 AM
