Old 11-06-2011, 03:08 AM
bobmasa bobmasa is offline
Default PT 10 - mbox 3 pro problem with lion
hey, with my mbox 3 pro with pro tools 10 and Osx Lion the keys speaker select do not work I have to change the monitor speakers from the internal mixer, if the detachment firewire keys instead of work,do you think the drivers are not fully updated to lion?
thanks bob
Old 11-18-2011, 11:53 AM
fakewater7 fakewater7 is offline
Default Re: PT 10 - mbox 3 pro problem with lion
I totally agree. Same thing happening with me. I've uninstalled and reinstalled the drivers to no avail. Trashed mbox prefs and everything. Please advise if anything changes for you or if anyone finds a fix.
Old 11-18-2011, 08:40 PM
serio serio is offline
Dealing with said issues as well. Here are my symptoms:
Mono button not responding. But mono can be activated through control panel, which in turn causes the mono LED to light up on the physical box.
Speaker switch button won't cycle through output sets. Yet when different speakers are selected in the control panel, the corresponding LED color lights up on the box.
Multiple Mbox pro icons appear in the midi window of the Audio Midi Setup. I forgot wether a new one appears each time I launch pro tools or each time I turn on the Mac.
The control panel is set up properly to where the buttons should be working. For giggles I installed the Mbox Pro on my Internet use,Windows XP hard drive of my PC. The Mbox Pro worked fine. All buttons functioned correctly. So I am also under the impression that it's a driver issue with OS Lion.
Also, the box is working correctly in stand alone modes, which is how I'm using it now: ADDA mode connected via S/PDF to my 003R.
The Mbox Pro actually sounds very good and I hope they come out with updated drivers. They haven't fixed the headphone problem that some other people are having and its been acknowledged for several months. So I don't know if we will see a fix for this anytime soon either.
21.5" Mid-2011 iMac i5 QUAD 2.5GHZ 4G RAM ML 10.8.5--Pro Tools 10.3.9--Avid Mbox Pro / 003R--ICY DOCK MB664UEA-1S FW400 With: 500GB Samsung HD502HJ
Old 11-28-2011, 08:15 PM
Anyone using an Mbox Pro with Lion and NOT having these problems?
Old 12-02-2011, 10:41 PM
Demigrind Demigrind is offline
My Mbox 3 Pro mono button has not worked since I installed Lion. Worked perfectly in Snow Leopard.
3.06 GHz Intel Core Duo iMac, 8 Gig RAM, MBOX3 Pro with Pro Tools 9.0.6 Mac OS 10.7.3
Old 12-03-2011, 08:45 PM
Thank you very much for your input Demigrind. Hoping that Avid can provide updated drivers soon.
Old 12-10-2011, 09:59 PM
There may be good news for the folks with this problem. A fellow member was told by Avid that the problem is a known issue and that they hope to have a fix in an update.
http://duc.avid.com/showthread.php?t=313432
Old 01-15-2012, 03:26 AM
Angry Re: PT 10 - mbox 3 pro problem with lion
Salve PT10 con Mbox 3 pro e Lion, la scheda perde il segnale ogni tanto
devo spengerla e riaccenderla.
succede anche a voi?
i drivers sono ancora fermi al 17 agosto 2011 e sono beta.
qualche idea?
grazie bob
Old 06-03-2012, 09:33 AM
Exclamation Re: PT 10 - mbox 3 pro problem with lion
Hi, often my mbox 3 Pro firewire signal loses
I switch off and back on the card.
happens to you?
the drivers are still stuck at 17 August 2011 and are beta.
any ideas?
thanks bob
Old 06-03-2012, 04:19 PM
I've only had connection problems due to the included FireWire 800 to 400 adapter coming loose if I move my iMac. A one piece 9pin to 6pin cable solved this.
Mbox 2 driver problem(I think?), pro tools 10, Mountain Lion jjnapp macOS 0 02-15-2013 09:01 AM
Lion to SL drive problem colinmansfield macOS 4 03-27-2012 06:46 AM
MBOX 2/PT 10.1/LION no sound problem charvin macOS 1 03-20-2012 07:25 PM
Anyone else having a problem with CEDAR DNS One and Lion? jmp Post - Surround - Video 4 10-27-2011 02:43 PM
Black Lion MBox and MBox 2 mods vocalvoodoo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 12-13-2006 07:28 AM
