Old 11-18-2013, 08:13 AM
Ivan R Ivan R is offline
Default Re: "Could not create a new document because assertion in..."
Had the same problem at first start of PT HD. After reading this thread, I started PT, get to Setup-Playback Engine, set it to my audio-device, close PT and restart. After restarting everything seems to be ok, no warnings, no problems. May be this solution will help someone)
Old 03-11-2014, 12:48 AM
Stephen Bond's Avatar
Stephen Bond Stephen Bond is offline
Originally Posted by mattmanix View Post
I had this error on my initial startup of PT10. Repaired permission, trashed incompatible plugins, used the "ProTools Pref and Database Helper" app (look it up) restarted several times, no dice. I finally got it to work doing this. Hold down "n" while starting PT (which I guess is standalone mode from what I've read). I pressed "n" before I launched PT and held it down until I got a dialog box asking to create a new session, etc. It started up no problem and asked what playback engine I wanted to use. Can create new sessions on start now and open up older sessions. I haven't had to start PT up using this process again since I did it the 1st time. Haven't gotten to put it through the ringer yet, but will re-post if I ever run into an error like this again. Hope this helps.
+1
Many thanks for posting :)
Stephen
Mac mini M1 2020 16Gb Memory- 256Gb Storage, Monterey, Pro Tools 2022.9, Focusrite Scarlett 2i2
https://www.waves.com/r/djgsi6
Old 02-25-2015, 08:17 PM
okgb okgb is offline
Easily solved the problem for me , Thanks!
10.3.1 "Could not create new doc because Assertion in.." MarkH macOS 19 12-26-2014 09:09 AM
Could not create new document because assertion spiker macOS 1 07-01-2013 02:06 AM
"could not create a new document " paulstapp Getting Started 1 06-19-2013 02:59 PM
PT Could not create a new document… assertion frcjt macOS 2 02-27-2012 05:29 PM
