Old 12-21-2014, 02:36 PM
dr_daw's Avatar
dr_daw dr_daw is offline
Default Air Creative install problems [solved]
Good afternoon all,
Finally have time to run some tests in OS X 10.10 with PT 11.3
System:
Late 2012 MBP i72.6gHz, 8gig Ram OSX 10.10 w/ clean install of PT 11.3
Waves plugs = working
Test system drive:
USB 3 Seagate BU plus (no-problems in the past using these as test drives)
Audio drive:
Glyph GPT50 via FW800
Interface:
Saffire Pro 40 w/Adat locked OctoPre via daisy chain FW400/800
So here is what I did:
- Install OSX 10.10 on clean partition
- Optimized OSX
- Installed Saffire Mix Control
- Installed iLok manager
- Installed Pro Tools 11.3
- Tested the system - opened various sessions both audio and post, no problems
- Installed Waves V9 (offline installer)
- Tested the system - playback issues ALL DISTORTED
- Turned the system off and went to bed
- Tested the system the next day, sessions loaded up fine - NO PLAYBACK problems
Here's where I'm stumped:
- Installed Air Creative 11.1
- Tested system and get distorted playback
- Restart = No change
- Repair permissions = No Change
- Complete shut down = No Change
- Moved all plugins to 'Unused' folder = Problem solved
I tried to search on here for answers, but it's like looking for a needle in a haystack...especially since 11.3 only came out a few days ago. Anyone see where I may be making a fatal error? Should've I installed the Air first before PT's?
Cheers
FBR recording - https://www.facebook.com/fromthebase...cordsrecording
@FBRrecording - Instagram
Rig
MBP 15" High Sierra 10.13.3, i7 2.6Ghz, 8Gb DDR, 750Gb 7200rpm, PT 2019.5, Focusrite Saffire Pro 40, Octopre MkII, Glyph GPT50, Avalon 737sp, AMS Neve 1073's, API 512c, CAPI 312's, DW drums, Fender Guitars/Amps, AKG, Rode, Sennheiser, Neumann U87 & KM184's, Coles 4038, Equator D5 monitors
Old 12-21-2014, 03:10 PM
dr_daw's Avatar
Default Re: Air Creative install problems {SOLVED}
Ha! After I hit return on my post I realized I never tried trashing my Prefs!!!
Trashed prefs using the helper, repaired permissions, restarted...viola!
Now on to testing Mini V
Rig
Old 12-24-2014, 09:05 AM
dr_daw's Avatar
Default Re: Air Creative install problems NOT {SOLVED}
Bah, jumped the gun. So far my tests have resulted in having to trash the Prefs/Databases and rebooting everytime I want to use Pt's. I'm guessing the best option will be to wipe the drive and try again?
I know the culprit is the Air Creative instruments, when I move them to the Unused folder everything zips along.
Rig
Old 12-24-2014, 02:52 PM
dr_daw's Avatar
Confirmed, Xpand!2 is the culprit! I'm a little unfamiliar with this synth as I rarely use it, but needed to mock up a strings idea for one of our new songs. I'm wondering if it's related to this being a USB3 test drive from Seagate which I would assume is 5400rpm.
Anyone have any insight? When I put only the Xpand!2 instrument in the unused folder Pro Tools boots up and runs without distortion.
Rig
AIR creative collection - cannot install lanstrad macOS 13 03-12-2015 05:35 AM
How do I install Air Creative Collection 11.1.0? [solved] JGlen Windows 4 12-26-2013 05:45 PM
Creative Collection install problems stress2727 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 17 02-05-2010 01:43 PM
Need Help - Creative Collection´s Virtual Instruments wont load! SOLVED hernan1987 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 09-11-2009 09:14 AM
I solved the "unable to load midi" error for creative PCI niacin65 Digidesign Hardware & Software 0 03-20-2001 07:27 AM
