Old 02-05-2018, 09:06 AM
abc1mce2's Avatar
abc1mce2 abc1mce2 is offline
Default Re: Audio Zoom In and Audio Zoom Out Shortcut
Originally Posted by 64GTOBOY View Post
Set your zoom presets . Upper right corner of the edit window is the waveform and midi enlarge buttons. Left and right click to get the size you want then save it as a zoom preset.
Good idea.
What is more relaxing than Music?
Pro Tools Carbon for macOS 12.7.4
My HDX for Windows11.
Gigabyte Z490 Vision D - BIOS F21b
Intel Core I9 10850K Windows11 / macOS 12.7.4 Hackintosh / 32GB of Rams
Avid Carbon/HDX 2024.3 Ultimate - 8x8x8 HD I/O - PT Dock - PT Control - Artist Mix (1)
Universal Audio Apollo Twin|X - UAD2 Pci-E and Satellite USB Octo v.11.0.1 - SOLO 610 - Twin-finity
Bricasti M7 (2)
Lexicon PCM96
Neumann KH805 - KH310
Yamaha NS-10M
Avantone Mixcubes
Grace Design M905
Etc, etc, etc.
Old 02-05-2018, 09:21 AM
Jperkins Jperkins is offline
Originally Posted by BScout View Post
And that is what I told you how to do in post #2. That is exactly what command+option+ square bracket does. That does Audio Zoom In and Out
And the other setting of command+ square bracket does the other part of that section of tools: Horizontal Zoom In and Out.
That is why they are one modifier key away from each other.
Thanks I interpreted the bracket symbol in your post as something else. This is what I'm looking for. Much appreciated.
iMac Pro 3.0GHz 10-Core • 64GB RAM • SSD for OS and audio • MacOS 10.13.3
http://www.mysteryroommastering.com/
http://www.justincarlperkins.com/
Old 02-15-2018, 06:24 AM
Default Re: Vertical Waveform Zoom Shortcut
the shortcut is
cmd+option+ [ or ] for vertical zoom
and
cmd + [ or ] is the horizontal zoom
I'm using PT 2018 and for some reason only the shortcut to vertically zoom down is working, but it doesn't go in very refined steps. It takes somewhat large steps.
The shortcut to vertically zoom up does not work at all.
Is anybody able to vertically enlarge the waveforms using cmd+option+ ]
cmd+option+ [ works for making the waveforms smaller.
Old 02-15-2018, 09:39 AM
Originally Posted by Jperkins View Post
Thanks but this isn't working for me.
To be clear, I'm trying to zoom in the waveform so that it becomes inflated so I can view low level audio stuff.
I'm not asking to make the track larger.
Audio Zoom In and Audio Zoom Out is what it's called when I do it manually.
1st response is correct. Cmd-Opt-] and Cmd-Opt-[ zoom vertically. They do not change track size. And yes, it works on every rig. Is it possible you have some other shortcut interfering with this?
http://www.richbreen.com
Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock
Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6
I can not make vertical zoom Shortcut cmbourget Windows 8 05-08-2015 04:35 PM
Vertical zoom to show default waveform height (Audio) with D-Command ? Hanswurstlsepp ICON & C|24 0 06-30-2011 03:55 AM
Vertical edit zoom shortcut, where / what is it? Strebor24 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 05-29-2010 06:15 PM
Waveform vertical zoom thing... Kuba Pietrzak Post - Surround - Video 6 01-17-2008 12:31 PM
Vertical single waveform zoom - not working sonuslab Pro Tools M-Powered (Win) 7 10-19-2006 05:34 AM
