Old 10-16-2017, 02:33 PM
[email protected] pqlior@mac.com is offline
Default Overnight, VE instance pushes CPU 30%-40%
Hey guys, without any change, I noticed that my instance of VE in my mix session bumps the CPU usage 30%-40%
Anyone else has this bug? This session sat around 50% last night and today is in the 80's
Lior
HD Native * PT 2018.12 * OS X 10.13.6 * MacPro 12 Core * 2.4GHz 24GB Ram * 2XUAD2 Octo * Waves Platinum * Lexicon PCM Native Bundle * Sound Toys Bundle* AutoTune8 * NI Komplete11 * BFD3 * Synthogy Ivory II* Vienna Ensemble Pro * Spectrasonics * Slate trigger2 *xFer records * Softube * Vienna Ensemble * DMG Expurgate * Massey DRT2 *
iPad Air/Avid control * EuCon 18.3.0.217 *
Old 10-17-2017, 04:31 AM
Default Re: Overnight, VE instance pushes CPU 30%-40%
Memory leak? Have you rebooted? That may fix the issue.
Jack
QAPLA!
Old 10-17-2017, 07:12 AM
Rebooted. Didn't help...
Anyone else? VE people also suggesting memory leak. Workaround anyone?
Lior
____________________
Sent from an inherently faulty typing apparatus... ;-)
Lior
Old 10-17-2017, 10:21 AM
Trashing prefs seems to have done the job...
I made sure to build clean prefs on a blank session, quit, restart, and ONLY THEN open the last session.
CPU usage is down to the 50% area now.
Lior
Old 10-17-2017, 10:25 AM
Aaaaaaand it's back. Took al of 3 minutes.
Lior
You're talking about trashing PT prefs right? I still think it's a memory leak.
Jack
QAPLA!
Old 10-17-2017, 10:27 AM
Yes- PT prefs. How do you address a memory leak?
Lior
Old 10-17-2017, 10:35 AM
Generally you fix a memory leak by rebooting the computer. How to find what's causing it is a bit more difficult. Strip out everything from VEPro and see if you have issues. If you still do remove VEpro from the session and continue. If you still do it's in PT. Keep removing stuff until the leak stops. A memory leak is something where memory usage increases for no action on your part and keeps increasing.
Jack
QAPLA!
Old 10-17-2017, 10:56 AM
VERY strange symptoms. I went back to the clean session I saved today (of last night's mix) after the prefs trash and it's fine... (with the same VE session attached to it) If I import a plugin from last night's session (A UAD SSL strip) it jumps back up BUT doesn't go away when I remove the plug. (that track is NOT sending to VE)
Seems to be related to internal bussing... When I Open the session, it's fine. Then, when I put my 'print track' into INPUT, the session jumps 35%
I've been working this way for YEARS and it never behaved this way...
Lior
Old 10-17-2017, 01:24 PM
Do you have a send to a 'bus to nowhere'?
But I rarely pay attention to the cpu usage window in PT anyway. Unless I have an issue I don't even open it.
Jack
QAPLA!
banking pushes tracks to top of screen Goombot Artist Series 13 10-27-2015 06:57 AM
Bounce to Disk adds 120 samples - pushes out of sync w pics bootc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-08-2008 06:50 PM
Fade Pushes Track Forward emcicle 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-11-2007 05:07 PM
Do we turn the computer off overnight? jeremyroberts Pro Tools TDM Systems (Mac) 6 07-18-2005 09:13 AM
overnight timecode problem audiokraftwerk Pro Tools TDM Systems (Mac) 1 03-14-2001 06:51 AM
