DAE Error 728: MacMini 2012 + 003R
I'm getting DAE Error 728
system specs MacMini 2012 Digi 003R I have to use a firewire 800-400 adapter in order to connect the 003R to Macmini. Daisy chained to 003R is Canopus ADVC110. Note: with the same connections above using MacMini's I/O, PT 10 runs well. Able to display video via FW out. any clues?
- Recording studio Dubbing House in Makati, Phiippines |
Re: DAE Error 728: MacMini 2012 + 003R
That sounds like quite a lot of IO you're trying to get through that firewire bus... Have you tried changing the order of firewire devices plugged in?
I had all sorts of issues with firewire when using a ADVC110 a while back. It seemed quite flakey, especially when other things were on the same port.
He used to cut the grass...he was a very nice boy... |
there is only 1 firewire port on MacMini.
daisy chaining is supposed to be common for FW devices
Yes, this is true. I know the mini only has one port, but changing the order that the devices are plugged in can sometimes make a difference.
Do both the devices have two firewire ports? If so, swap the firewire cable coming from the mac from one device to the other, then chain the other off that. It may make a difference... or not...
not a fix for the 003R issue,
but I tried my 002 instead and works like a charm. canopus advc110 daisychained to 002's firewire port
Presonus Firestudio/003R fatal error | Fastermouse | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 06-23-2011 06:52 PM |
Error -6085 on 003r with windows xp | tkomforty | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 23 | 02-18-2010 01:31 PM |
PT8 -9129 error - No problems in 7.4 - 003R | Alex MacFarlane | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 12 | 01-09-2009 03:30 PM |
003R help (-6097 error) using Arturia CS-80v | joeldadrummer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 04-25-2007 06:21 PM |
