Old 10-14-2017, 09:25 AM
IrelandM IrelandM is offline
Default Can it be done?
To Avid / S3 Users,
I would like to use the ethernet RJ45 port on my MacBook Pro and
have the ability to run an Avid S3 controller with a pair of AES 67
Genelec Studio Monitors via its single connection can it be done?.
Regards
Old 10-15-2017, 01:05 PM
EddieJones's Avatar
Default Re: Can it be done?.
The S3 is AVB only.
Old 10-15-2017, 04:54 PM
mattrixx mattrixx is offline
I would love it if S3 support AES67. That would be so good!
Matt McKenzie-Smith
mattrixx.net
SourceConnect - mattrixx
AVID Collab user - mattrixx
MacStudio Ultra / LogicProX / IzotopeRX10+ / SourceConnect / MelodyneStudio5 / WAVES Mercury / NI KompleteUltimate / ProToolsUltimate / RME UFX, UFXII, Babyface / AVID S3 + DOCK / Barefoot MM27 gen2 / Barefoot FP01
Old 10-16-2017, 04:38 AM
Originally Posted by EddieJones View Post
The S3 is AVB only.
Yes I understand that the S3 is AVB but maybe I did not address my question correctly.
Is there any way to connect a switch or ethernet hub allowing me to use one single RJ45
cable on a Mac, without the need to disconnect the Avid's S3 ethernet and Eucon control
cable, but still have audio directly available for monitoring into AES67/RAVENNA Monitors.
Regards
Old 10-16-2017, 09:41 AM
EddieJones's Avatar
This depends on the amount of audio you will be using. Generally speaking, we don't recommend running EUCON and Audio Over Ethernet on the same network but if you are not using the full channel count, you might get away with it.
