HELP!!! records fine, but playback in fast-forward
I just got PT8 and installed it on my MacBook Pro (Snow Leopard). i already downloaded and installed the latest update for snow leopard and that fixed a few issues i was having.
the only remaining problem is that when i record, i will play it back and it will sound like it's in fast forward. i can tell that the "clock" at the top of the edit window is counting slower while recording. then, when i playback at my set tempo, it sounds faster because of the speed change - the clock moves at the set tempo in playback. so, i know WHAT's happening, but i don't know HOW to fix it. anyone had this problem or have any remedy to fix it? thanks. Running: ProTools LE with MBox 2 mini Mac OS X 10.6.2 ProTools 8 |
Re: HELP!!! records fine, but playback in fast-forward
Never used it myself, but maybe this feature is your problem:
Mac Pro 8-core 2.26 | 6 GB | OS X 10.6.8 | PT LE 10.0.0 | MBox 2 / ECHO AudioFire PRE8 MacBook Pro i5 2.3 | 4 GB | OS X 10.6.8 | PT LE 10.0.0 | MBox 2 / ECHO AudioFire PRE8 |
What is your clock reference?
Eric Seaberg • San Diego, CA A.E.S., I.E.E.E., S.M.P.T.E., S.P.A.R.S. |
Eric,
follow the link i the first reply...the pic that you see on that page is what i am referencing |
I think there are some misunderstandings going on here.
I think mr. Seaberg is asking if you have some external digital sync clock signal controlling your audio interface. And what bfx is referring to is a feature in PT that lets you record or playback at half speed: Shift-spacebar: playback at half speed. Shift-command-spacebar: record at half speed. And playing back a half speed recording at normal speed would result in a double speed chipmunk effect.
Mac mini M2 16GB RAM macOS 13.4.1. PT Studio 2023.6. Topping E30 II DAC, Dynaudio BM6, 2 x Artist Mix, SSL UC1, Control on iPad. |
THANKS soooo much for the help guys!!! what a dumb mistake on my part.
Playback During Fast Forward | mentalsanityoff | macOS | 1 | 04-03-2012 06:33 PM |
PTLE 8.0.4 recording/metering problem (input mon. playback fine, but records silence) | blast9 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 08-17-2010 08:45 AM |
How come when I fast forward are my | renips1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 03-23-2010 08:58 PM |
Records Just Fine ... But Playback is DELAYED | rselly | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 01-07-2006 12:52 AM |
Fast Forward/ Rewind | Greg Malcangi | ProControl, Control|24, Command|8 | 3 | 12-02-1999 07:59 PM |
