  #21
Old 01-10-2012, 03:53 PM
nerd513 nerd513 is offline
Default Re: Bounce handler can not keep up (-9132) - BUG
native is very unpredictable but suit urself... u might as well get used to using workarounds as their will be many using ur computer as a host processor...
  #22
Old 01-11-2012, 06:04 AM
dougied dougied is offline
Originally Posted by Keith Matthews View Post
Hi all,
I am getting an error
" Bounce handler can not keep up (-9132)"
when trying to bound down a single bass guitar track to 24bit Summed mono WAV.
Only plugins are the new Channel Strip on the track and a click track.
Its a 27" i7 iMAC with 8 gig men PT 10 so it should not be a processor problem. Seems like a bug to me.
It occurs about 7/8 of the way through the bounce.
No other Apps are running.
H/W Buffer size is all the way up at 1024
help 8-)
27" iMAC (2010) i7 8GB
Mac OSX Lion 10.7.2
Protools 10
Digi002 Console
I thought I was the only one. I can't bounce down at 1024 either with just a simple 14 track mix w/ reverb and EQs. It's kinda lame. The Avid Core Audio buffer change doesn't work, they really need to fix this crap.
Mac Pro Dual Quad 2.8Ghz 2008
MacBook Pro i7 2012
OSX 10.8.5 - OSX 10.7.5
Pro Tools 10.3.7 - 11.1.2
6GB RAM
Universal Audio Apollo Quad!!!
Eleven Rack
Focusrite Octopre MKII
Yamaha HS80s
Rockit RP5 Monitors w/ RP10 sub
  #23
Old 01-11-2012, 07:55 AM
crizdee's Avatar
crizdee crizdee is offline
This is a known issue and documented in the Pro Tools 10.1 release notes.
the work around is to use record to disk instead. route your mix bus to an audio track ann record the mix into this track. the track can then be accessed from the audio plugins folder. or right click in the clip list and reveal in finder.
You will want to open the session window apple+2 and select interleaved before doing this.
And also export as 44.1 16 bit if you want to play it on CD etc.
Chris
Producer, Engineer,
www.ukmastering.com
  #24
Old 01-13-2012, 01:16 AM
Keith Matthews Keith Matthews is offline
Talking Re: Bounce handler can not keep up (-9132) - BUG
It was never a problem with PT8 or even PT9, and its no problem on Windows, which annoys me because the whole reason I run it on MAC is for stability. Or at least it was 8-)
Seems to me Avid have no idea and are not interested, which is so unlike the Digidesign days 8-(
I guess I'll just have to try a reload of Lion and PT
As far as work arounds go, it doesn't help with Quicktime bounces which is what I am currently trying to do.
Thanks for the advice though..... I sure with I could afford HD etc
Regards.......Geo
oooOOOooo
  #25
Old 01-16-2012, 02:03 AM
mbat4100 mbat4100 is offline
I am getting the same message when trying to bounce to disk. Tried removing plug-ins to no avail.
Worked when I changed bounce bit rate from 24 to 16 bit.
Aaagh. Not really desired solution.
  #26
Old 01-17-2012, 09:51 PM
Wink Re: Bounce handler can not keep up (-9132) - BUG
Originally Posted by mbat4100 View Post
Well I think I may possibly have cracked it 8-)
No Thanks to Avid for total lack of help, I still consider it a Bug because DAE should NOT be this touchy.
Here is what I did.
1) Delete everything in /Library/Caches
2) shutdown
3) Restart in Safe Mode (Hold Shift on Boot), This clears all the MAC OSX cruft.
4) After Boot, Restart back into normal Mode.
Since I did that I have not had the -9132 error. Though I haven't tried Bouncing a Quicktime movie or 32bit sessions yet, both MP3 and WAV seem to work OK.
I'll see how it goes.
Regards.......Geo
oooOOOooo
  #27
Old 04-03-2012, 01:33 PM
Heights941 Heights941 is offline
I was having the same problem... Bounced it to the desktop instead of an external hardrive and it worked perfect. I must say this is very embarrassing in the middle of a session. I've been with pro tools since 6, mac pro quad core, 9 gigs of ram... NEVER had this problem until pt 10! wtf?
  #28
Old 04-03-2012, 01:36 PM
and it was the first session with this client, so first impression kinda sucked... although the mix was still good.. (oh and i didnt figure it out until after they left) AVID should give me some kind of credit for this ...being that I payed $500 to upgrade from 8... AVID? how much do you care about your loyal customers?
  #29
Old 04-21-2012, 07:43 AM
louieshowers louieshowers is offline
THIS BOUNCE HANDLER CANNOT KEEP UP ERROR...IS SIMILAR TO SPENDING LOTS OF MONEY ON an EXCITING DATE...and at the end of all of your hard work looking for "closure" at the end of your night, your date simply abandons you....
THIS IS SUCH A PAIN...has anyone found a fix for this?
  #30
Old 04-22-2012, 03:38 PM
Terry Dycus Terry Dycus is offline
I have had the same issue since going to PT10. Installed latest update and still same error. Never had this problem before PT10 no matter how complex the session was. Avid? Ssession will also pause during playback. Again, rarely had this issue with previous versions of PT and lesser machine. Come on Avid.
PT10.1
MacBook Pro i7 2.66GHz
8GB RAM
OS 10.6.8
Best regards,
Terry Dycus
Bounce handler cannot keep up. (-9132) digitalint 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 12 04-13-2013 05:31 PM
Bounce Handler -9132 cherrymetal 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 03-03-2005 05:09 AM
Bounce Handler cannot keep up -9132 halley362 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 02-13-2005 08:01 PM
Bounce Handler Can Not Keep Up (-9132) ROME 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 07-05-2004 08:25 PM
Bounce Handler cant keep up(-9132) rtm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 03-08-2004 08:55 AM
