Old 08-01-2006, 01:34 PM
scottives scottives is offline
Default Multiple Output Assignments
I am running Mix24 with 9.2 and all of a sudden I cannot assign multiple outputs via the keystroke. Has some thing been inactivated? A ny help would be appreciated.
Thanks,
Old 08-01-2006, 05:24 PM
Andre Knecht Andre Knecht is offline
Default Re: Multiple Output Assignments
When you say “the keystroke,” do you mean “Control+Assign-From-Output-Pop-up?” That feature was never disabled in any version of PT TDM since its original introduction. A more detailed explanation might be helpful.
Short of that, make sure you haven’t disabled any paths, or that any of the outputs you are trying to address aren’t already being used by an insert (which makes them unavailable).
Last but not least, you could Trash PT and DAE preferences, as well as the DigiSetup file. And rebuild the desktop.
IHTH.
Andre Knecht
We’ll fix it in the shrink-wrap. (Frank Zappa)
Old 08-02-2006, 06:43 AM
Thank you for your reply. Yes, by pressing the Command Key then clicking the output I was able to assign multiple outputs (For Headphone assignment, etc.). Now I only can assign one. I set I/O to default yet to no avail. Hopefully I will not have to rebuild desktop, but I will if I have to.
Thanks,
Scott
Old 08-02-2006, 08:04 AM
Stig Eliassen's Avatar
You do mean Control-click, yes?
Old 08-02-2006, 05:25 PM
[…] Hopefully I will not have to rebuild desktop, but I will if I have to.
Scott,
rebuilding the desktop isn’t anything dramatic. In fact, it’s something one should do periodically and with regularity with OS9. Better yet, use Disk Warrior, which does a much better and thorough job than the OS ever did.
IHTH.
Andre Knecht
[Q] How To Change All Output Assignments At Once? Jason Kardong Pro Tools TDM Systems (Mac) 8 03-13-2013 11:30 AM
output assignments on D-Command zakco ICON & C|24 3 09-07-2012 03:51 PM
Multiple VI MIDI Assignments spearson8 MIDI 2 08-22-2012 07:37 AM
Weird issue with output assignments jkess Pro Tools TDM Systems (Mac) 13 07-11-2011 11:44 AM
Odd output assignments sw rec 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 06-24-2009 05:20 PM
