#61
Re: Lightbridge Discontinued!
Correct, only the 16x series has the Big Ben clock in it. And the new Symphony IO has a new improved version of that.
#62
Anyone else worried that since they discontinued the product that drivers for new OS's (like 10.7) wont happen? I was going to use lightbridge for stemming from Logic to protools, but dont have a proper protools machine yet; was going to use my macbook and lightbridge for now, but dont want to be stuck if/when I get a new machine.
Has M-audio / Avid been good about keeping their drivers up to date on discontinued products? Anyone know if they plan on releasing a new replacement device? This sucker seemed to be PERFECT for my needs and I'm surprised to see it discontinued! |
#63
I am not really concerned. Either I won't upgrade my software or I will upgrade the interface. If you wait for a piece of gear that will be supported in perpetuity, you will wait a long time.
It is a $300-ish piece of gear. That is not going to make or break my budget.
| Logic Pro 9 | Reason 6.5 | Pro Tools 10 | MOTU UltraLite mk3 | RME ADI-2 | Summit Audio 2BA-221 x 2 | MOTU 8pre x 2 | | Mac Pro (4,1) 2.26gHz Xeon x 2 16gB OS X 10.7.4 | Macbook Pro (8,2) 2.2gHz i7 Quad 16gB OS X 10.7.4 | |
#64
Don't think Duet has a Big Ben either ...not for $300, etc.
So the Lightbridge can connect 4x8ch mic pre's? How are you getting the Lightpipe from its out's into the Mac?
MacBook Pro 15in, 2.3gHz,i7 PT 2021.x PT12.8.x |
#65
It is a FireWire interface.
#66
Firewire does that trick with the Lightbridge. Great piece. It still works fine for me in PT9. As to the clock -- the DUET has the exact same clock in it as the LUCID Genx6.. which is the same 'chip' as the BigBen has. It's like a 'little cousin' to the BigBen -- but the 'chip' is the same.
Rig 1-Mix/Mast: PTHD 11.3.1; MacPro 6core (6,1) 3.5 GHz Xeon E5; 10.10.3 (SSD Drives for audio); Apogee DUET, FireStudio2626 as Hware Inserts to PT for outboard Rig 2-Cutting&Remotes: PTHD 11.3.1; MacBook Pro (8,1) 2.8 GHz Dual i7; 10.9.2 (128GB int '6G' SSD drive); Profire LightBridge (FW800), 32ch Presonus Digimax FS |
#67
Have u used it? The presonus
#68
This was flat out the most poorly made interface I have ever bought. How they could sell something that includes a 6 pin firewire cable and a power supply, but NO documentation that warns you to NOT use the power supply at the same time as a 6 pin firewire cable because it will ruin the unit..... Major, major design flaw that never should have made it to market. Good riddance.
- John If a MIDI event triggers a sample of a tree falling and there's no one there to hear it, does it make a sound? |
#69
#70
It is actually a pretty common issue with some bus-power capable FireWire hardware. However, they should have put that information in the initial documentation. I have a newer version and it does indeed have those instructions (not to plug in both) as well as a big yellow insert that says the same.
003 Discontinued? | bootc | Pro Tools 10 | 58 | 12-05-2011 06:15 PM |
Is 003 really discontinued? | ripekeai | Pro Tools 9 | 15 | 03-29-2011 06:05 PM |
001 DISCONTINUED. | jeml | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 09-21-2004 08:24 PM |
discontinued 001? on a G5? | rgriff | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 06-27-2003 03:20 PM |
001 being discontinued??? | fabpab | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 11-10-2002 04:18 AM |
