Re: analog channel
It sounded cool when I first got it. Fun to see if it could help get more of the analog vibe into protools, but I didn't keep it on much... I always come back to the "less is more" approach with my main focus on the signal and sound that goes into protools, so I can keep plugins and effects to a minimum, unless I want that "modeling" effect.
I have kept AC2 on the kick tracks most of the time, and sometimes an AC1 and/or AC2 might get used for a vox or guitar depending on the track, but not much else gets it... |
Re: analog channel
I don´t use it on that many tracks also (I did at the beginning).
I keep it on drum subgroups and on acoustic guitars mainly. Peter
http://www.merlinsound.de |
Re: analog channel
I used magneto ( a cheap vst plug simulating tape compression characteristics ) a lot , and i found , that using this very very subtle on each (every !) track helped the mix very much in the dynamics perspective . the trick is , you wont`t really recognise the loss of "aggressive" transients and thus the thickening on a single track , so you tend to overdo it ...... just the same thing you had to learn recording with analog tape , pump kick and snare , be very cautious with hats and overheads , really drive the bass guitar into tape compression and so on .#
plus the attack and release times of the compressors you use in mixdown are much less crucial . |
Re: analog channel
I agree with the above, I find the AC1 great on bass guitars - to give a bit of bite.
Also find the AC2 great on electric guitar and 'hard-wired' on drum sub-groups. But on every channel? This is what I initially thought - but no thanks, it's a great, great plugin - but in moderation. Pete |
analog channel
analog channel seems very powerful. It also seems that with the wrong application It could ruin a mix. I am wondering if anyone is having great success with it.
One question I have is: If using AC1 on every channel and AC2 on the main would it be unnecessary or possibly bad to use something like Maxim or the L1 on the main. I am having a little trouble differentiating the compression characteristics of AC with the standard compression techniques |
Analog Channel(AC1) or Renaissance Channel | Choral14 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 10-29-2006 07:07 AM |
mcdsp Analog channel vs analog channel LE | psus15 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 02-13-2006 11:45 AM |
Analog Channel | GregJ | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 02-14-2005 07:33 PM |
WHY/WHEN do you use Analog channel 2? | Wnna | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 07-18-2002 04:34 PM |
analog channel | drenched | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 10-16-2001 12:32 AM |
