Plugin cannot be found by older Pro Tools projects
Hello folks. After reinstalling Pro Q, Pro Tools 11 cannot find it with any of my previous projects. I might have installed it in a different folder, not sure. Is there a way to tell PT where ProQ is located? Or some other way?
Re: Plugin cannot be found by older Pro Tools projects
Is ProQ a AAX64Bit plugin?
If not, PT11 won't see it because it needs to be AAX64 format. Previous PT versions used RTAS format.
Too much blood in my drugstream Motherboard: Gigabyte Z690 AERO D CPU: Intel Alder Lake Core i9-12900K CPU Cooler: Noctua NH-D15S RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz) Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples) 1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro) GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4 PSU: Corsair HX Series HX850 Platinim CASE: Fractal Define XL R2 PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII HD 96I/O |
It is AAX 64 bit.
It has to be in the same folder with all your other PT11 aax format plugins. Unless you re-directed the installer somehow it should have installed in the correct folder.
Guys figured it out. The old projects were done with Fab Pro Q. I only had installed Fab Pro Q 2 hence the issue. All fixed. For those that own ProQ2 licenses Fab will give you ProQ license key for free.
Btw, GuitarDom rocks! He knows everything :) |
saving projects as older versions? | gdgross | Pro Tools 11 | 2 | 05-21-2015 01:45 PM |
Question about an older Mac Pro and possible older versions of Pro Tools HD | wolfman_rob | Pro Tools TDM Systems (Mac) | 13 | 07-21-2013 01:29 AM |
Mtron Pro Plugin is not found on Pro Tools 10.3 | shamanrock | Windows | 0 | 10-30-2012 10:02 PM |
Opening Pro Tools 9 Projects in Older Versions | br567 | macOS | 3 | 03-09-2011 09:48 AM |
Converting Projects from Older LE to LE 8 (also PC to Mac) | ostrich99 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 02-03-2011 07:23 PM |
