Old 11-21-2019, 06:52 AM
rmccam rmccam is offline
Default New Mac Pro, AJA & Frame Accurate Sync
Hi Everyone,
I need to upgrade my computer so I'll likely be pulling the trigger on a new Mac Pro. The last while I've been using just a computer monitor for video playback, which obviously isn't ideal, but when I overhaul the system I'd like to go back to having a proper video out to a TV, ideally with proper sync to Pro Tools.
I'm looking at used AJA Kona LHi cards. Does that still make sense in 2019 with the new Mac Pro? The majority of the work I do is commercials, so I'd likely transcode to 1080 even if something ever did come as 4k.
Second part of the question: I'm currently using an OMNI, which I don't particularly love, but I have an Apogee Rosetta 800 and Coleman 5.1 monitor controller kicking around and thought to switch over. If I want to properly sync video, would I just have to get a Sync HD and use wordclock to sync to the Rosetta and RS-422 from the AJA to the Sync HD? Or do I need to keep an Avid interface?
Thanks in advance!
Ryan
Ryan McCambridge
Producer • Sound Designer • Mixer
Old 11-21-2019, 07:03 AM
reichman's Avatar
reichman reichman is offline
Default Re: New Mac Pro, AJA & Frame Accurate Sync
First part of your question: a surprising number of our device drivers are 32-bit. Check with AJA or Blackmagic to see what cards are supported with their 64-bit drivers for Catalina. There are A LOT of unanswered questions surrounding Pro Tools and Catalina.
Nathaniel Reichman
Producer/Re-recording Mixer - New York
Nathaniel Reichman | IMDB | LinkedIn
Old 11-21-2019, 07:07 AM
Oh ****, that's a very good point. I didn't even think of that. That's a whole other level of problem. Ha Ha! I'll look into that. Thanks!
Assuming it will work, am I correct about the sync side of it with the Rosetta, or am I missing something?
Ryan McCambridge
Old 11-21-2019, 07:13 AM
reichman's Avatar
When I measure the Avid Video Engine and an AJA interface with a SynCheck, the sync is so tight that I haven't bothered with the expense of running a SYNC and house clock. But technically you should. I know those setups are running even tighter than mine. I guess the real question is, how often are you and your clients making critical lipsync/ADR decisions in an attended session? If the answer is never, you just saved yourself some dough.
Nathaniel Reichman
Old 11-21-2019, 08:21 AM
Well, according to this, the Aja Kona series is compatible with Catalina:
https://www.aja.com/news/top-stories/848
That's one less problem, I suppose.
Ryan McCambridge
Old 05-24-2020, 07:33 AM
bad jitter bad jitter is offline
I am wondering the same thing.
According to this page: https://www.aja.com/support/kona-system-configuration it seems that Kona Lhi is not compatible with the latest Mac Pro. It says that supported PCIe cards are KONA 5, KONA 4, KONA IP, KONA HDMI, KONA 1.
I would like to be wrong, as I have Kona Lhi. Anyone using it in new Mac Pro successfully?
Old 05-24-2020, 10:29 AM
I'm using an AJA KONA LHi in a new (2019) Mac Pro without any issues. I've had it running for months now.
Ryan
Ryan McCambridge
Old 05-25-2020, 11:10 PM
Hi Ryan. Sounds great, thanks for the info!
Old 05-26-2020, 11:59 AM
No worries. If you have any questions you can just direct message me.
Ryan
Ryan McCambridge
HTML code is On
Video Satellite - Frame or Sample accurate? Rainer Heesch Post - Surround - Video 4 05-14-2013 04:30 AM
Frame Sync or Frame Store - Plasma v. CRT Chief Technician Post - Surround - Video 3 10-10-2006 08:50 AM
Frame accurate capturing of Quicktime movies Basslab Post - Surround - Video 17 03-23-2006 02:17 PM
Frame accurate DV Captures mampam Post - Surround - Video 5 07-19-2005 06:43 AM
Sample accurate sync between two DAW's nobby 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-20-2001 03:34 PM
