Old 03-08-2013, 01:45 AM
Jakob Clemen Jakob Clemen is offline
Default HD Omni I/O with both AES and Adat
I'm trying to figure out how to expand my Omni's I/O in a cheap way until I can afford a 8x8x8, Aurora or similar.
I already have a Focusrite octo pre mk I with adat option, a M-Audio profire 2626 and a Saffire Pro 56 which I primarily use for live recordings.
I was therefore thinking on using both the AES input along with the Adat input.
Does anyone know if it's possible to run inputs via AES and Adat at the same time? If this works it would give me 16 inputs in a very inexpensive way sine I already have the interfaces :)
Thanks in advance
Jakob
Did you talk to your talkbox today?
Old 03-08-2013, 07:59 AM
nst7 nst7 is offline
Default Re: HD Omni I/O with both AES and Adat
There's no way to expand the Omni. It only does 8 inputs simultaneously, as is stated in the specs and description.
It can be any combination of inputs to do that, but it will still only be 8 inputs. For example, you could do 2 channels AES, 2 channels Adat. Or 4 channels analog, 2 channels Spidf, and 2 channels Adat. But it's only 8 inputs total.
Old 03-08-2013, 12:11 PM
dammn, I just thought I figured it out. I think I will go look for a used 192 I/O interface and use the interfaces I all ready own as preamps.
Thanks for the reply :)
Omni SPDIF and ADAT simultaneously? Tim R. Pro Tools HDX & HD Native Systems (Mac) 5 05-21-2013 10:10 AM
HD OMNi + 8 pre Adat how many inputs? Claudioska Pro Tools HDX & HD Native Systems (Mac) 6 02-18-2013 08:12 AM
OMNI Fried? Calling Omni Members - Check High Samplerates KingFish Pro Tools TDM Systems (Mac) 3 11-03-2011 09:19 PM
Be aware! Potential HD Omni buyers with treated Rooms and Computers. Omni Noisy Fan FRaNCo MuSiC Pro Tools HDX & HD Native Systems (Win) 0 09-25-2011 05:42 AM
HD-OMNI´s ADAT I/O dead...Firmware problem? 24BitMusic Pro Tools TDM Systems (Mac) 3 01-03-2011 08:55 AM
