Old 02-02-2017, 12:39 PM
jglunt2112 jglunt2112 is offline
Default No Click ii plugin in Pro Tools 12.5
I'm running Pro Tools 12.5 on a Windows 10 computer. I have no click in PT 12.5, though it used to be there, and in the same setup. Output on click track is set to 1 & 2. Track is not muted. Volume is turned up--way up. Click is selected in "Options." Metronome is on in the Transport Window. "Click during playback and record" is checked. I've hit #7 on the pad on the RHS of my keyboard--nothing changes. Apparently, my click ii plugin has disappeared. I tried re-installing the AIR Effects Bundle 12.0 twice. Still no click ii. Does anyone out there know what else I might try? Thanks
Jim
Old 02-02-2017, 02:32 PM
john1192 john1192 is offline
Default Re: No Click ii plugin in Pro Tools 12.5
Jim
a little confusing .. can you be more precise please
1) is there a Click Plugin in your Plugins Folder ??
2) if Yes, is there a Click Plugin on your Click Track ??
3) See Pic - is the ON Button lit up when you look at your Click Plugin (if you have one obviously)
4) the AIR Effects Bundle has nothing to do with the Click Plugin . it is a CORE plugin that is installed with Pro Tools ..
cheers john
OS 10.12.6 for PT 11.3.2 & 12.4 & above
Mac Pro 6-core 3.33ghz (2012) 24gb ram 256gb SSD
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS10.12.6 - PT 12.4 & above
lynx AES16e-SRC & Aurora 16
Artist Transport & iPad - Pro |Control - EuCon 3.7 (older Euphonix Branded MC Transport)
Old 02-02-2017, 03:35 PM
Hi John. Thanks for the reply. Strangely, I solved the problem. To answer your questions, (1) No, there was no Click plugin in my Plugins folder. That sort of answers all the other questions as well. That's what I meant when I said "Apparently, my click ii plugin has disappeared." I even checked the unused plugin folder this morning, and it wasn't there either. However, I decided to check the unused plugin folder again, and suddenly there it was. Where it appeared from I have no idea. Why it was in the unused plugin folder I have no idea. I'm not the smartest guy in the world, but even I can make it to "c" in the alphabet, and it wasn't in either plugin folder this morning. At any rate, I transferred it into the plugin folder and it's working just fine. Again, thanks for the reply.
Jim
Avid can you please sort out the click track & Click 2 plugin protoolsuserman Pro Tools 11 14 11-14-2013 09:11 AM
click plugin tlatham Pro Tools Software (Mac) 5 07-21-2011 09:51 AM
Using the Click Plugin tonesponge 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 05-31-2008 02:45 PM
Click Track - How to "UN" accent the click plugin pepperbox 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 11-02-2006 07:37 AM
Plugin click??? mixerboy Tips & Tricks 5 11-04-2002 04:18 AM
