Old 03-21-2020, 04:47 PM
Bob Katz Bob Katz is offline
Default Re: Urgent: Serious issue with clip effects
Originally Posted by The Weed View Post
Can you make a preset with everything turned off and then, instead of Factory Default change it to using your preset instead? I don't have Clip Effects as I'm on Standard not Ultimate, but I've done this with several of my AudioSuite plug-ins.
Thanks, Weed. Yes and no, please see later in the thread.
Old 03-21-2020, 04:48 PM
Originally Posted by smurfyou View Post
Hmm, the filters default to bypass on several Mac systems I run. Technically the filter section is in (green) but both individual filters are out.
Roger. I did not realize that the filter buttons 1 and 2 were ENGAGE buttons (see later in this thread), but the dynamics sections are engaged!
Old 03-21-2020, 04:57 PM
The behavior is definitely inconsistent. I cannot predict why some clips dragged into the session as "factory default" and some as my user preset. This behavior is not only worrisome, it's stress-provoking.
Old 03-22-2020, 02:53 AM
You mention Pro Tools 20, is this a pre-release version that could have different behavior?
Not to be flippant but there are two enable points with the filter section. There is the master Enable / In switch, the "power" button that lights up green. Then each filter has it's own enable, I think it's "1" for HPF AND "2" for LPF. The number itself highlights or dims depending on the enable state. Those default off for me. Are those defaulting on? That would be a big issue.
As I mentioned in the thread, you are correct. I misinterpreted the 1 and 2 buttons and did not realize they are ENGAGE buttons for the filters. Nevertheless, for sure the two dynamics ENGAGE buttons are engaged in factory default and this is as much if not more of a problem than the filter business.
Old 03-22-2020, 06:02 AM
the.engineer the.engineer is offline
Agreed
James Welch
Recording Engineer | Producer
Masterlink Productions
Mac Pro 5,1 (Mid 2010) | 3.46GHz Six-Core Intel Xeon | 32GB Ram | AMD Radeon RX 580 8GB | Apple 27" LED Cinema | 500GB Samsung 960 EVO M.2 SSD System Drive | 1TB WDC Sample Drive | 512GB Samsung SSD Audio Drive (temporary) | UAD-2 Quad PCIe
Mojave 10.14.6 | Pro Tools Ultimate 2019.12 | HDX | Avid Omni | Avid 16x16 HD I/O x2 | Digidesign 192 | Digidesign C24
Old 03-22-2020, 06:31 AM
Hey Bob,
I can’t recreate what you did to get the clip effect to default to my preset.
Could you run through it again?
Thanks
James Welch
Old 03-23-2020, 07:07 AM
New clips recorded in the timeline have the "defective" factory default clip effects preset applied. This is completely unacceptable. I've issued an Avid Support case.
Old 03-23-2020, 07:09 AM
Originally Posted by the.engineer View Post
Hey Bob,
Thanks
I'm not sure it's repeatable, to be honest. In some cases dragging a clip into the timeline the clip seems to pick up my personal preset. In other cases it comes up factory default. Just as bad or worse, is new clips recorded in the timeline have the "defective" factory fault applied (e.g. realtime bounces of a bus to a track to capture the master)
Old 03-23-2020, 09:49 AM
Sorry Will, typo. I meant to type 2019.12
Old 03-23-2020, 11:32 AM
No problem. Interested to hear what Avid say.
James Welch
Mac Pro 5,1 (Mid 2010) | 3.46GHz Six-Core Intel Xeon | 32GB Ram | AMD Radeon R9 280X 3072 MB | 256GB Samsung SM951 SSD Blade (PCIe) System Drive | 1TB WDC Sample Drive | 4TB RAID 0 Seagate Audio Drive | UAD-2 Quad PCIe
Mojave 10.14.5 | Pro Tools Ultimate 2019.5 | HDX | Avid Omni | Avid 16x16 HD I/O x2 | Digidesign 192 | Digidesign C24
James Welch
Clip effects and dock Moviesound Avid S1, S3, Dock and Control 5 08-11-2017 11:47 PM
Clip Effects SBP Pro Tools 12 1 06-12-2017 04:19 PM
Disable Clip Effects markuse_23 Pro Tools 12 0 01-31-2017 03:06 AM
Clip Effects Freezing Carl Lie Pro Tools 12 3 10-05-2016 04:24 AM
Issue dropping more than one clip into the Edit Window with Clip Transparency ON arb232 Pro Tools 12 0 02-10-2016 06:01 PM
