Old 03-19-2020, 08:08 AM
the.engineer the.engineer is offline
Default Hard Drive Choices in 2020
Hi Everyone,
Recently my Raid 0 array took a dump (2x 2TB 7200rpm Seagates) and freaked me out. I got it back working again after reseating the drives in the Mac Pro 5,1, so far so good.
Now Pro Tools is throwing -9073 errors all over the place even though my sessions are in the Disk Cache. I transferred a session across to my boot drive (see signature) and it works fine, no -9073 errors.
What's the next step? Replace the Raid 0 array with new spinners? Replace it with 2.5" SSDs? Or get anoyther PCIe M.2 board with more slots and run my sessions of a smaller NVMe drive?
Your advice is, as ever, greatly appreciated.
Best,
James
James Welch
Recording Engineer | Producer
Masterlink Productions
Mac Pro 5,1 (Mid 2010) | 3.46GHz Six-Core Intel Xeon | 32GB Ram | AMD Radeon RX 580 8GB | Apple 27" LED Cinema | 500GB Samsung 960 EVO M.2 SSD System Drive | 1TB WDC Sample Drive | 512GB Samsung SSD Audio Drive (temporary) | UAD-2 Quad PCIe
Mojave 10.14.6 | Pro Tools Ultimate 2019.12 | HDX | Avid Omni | Avid 16x16 HD I/O x2 | Digidesign 192 | Digidesign C24
Old 03-19-2020, 08:13 AM
arche3's Avatar
arche3 arche3 is offline
Default Re: Hard Drive Choices in 2020
Get 2 ssds put on the sleds. Plenty fast enough for protools. Don't need to raid 0 them.
Sent from my SM-G986U using Tapatalk
Old 03-19-2020, 08:20 AM
JFreak JFreak is online now
SSD into sled for boot drive and PCIe M.2 for audio/samples. As said, you can safely skip RAID altogether.
Old 03-19-2020, 02:40 PM
Just ordered a 2TB OWC for an audio drive. Should keep me going for now!
Thanks chaps.
James Welch
Old 03-19-2020, 04:50 PM
lesbrunn's Avatar
lesbrunn lesbrunn is offline
Why not NVMe for the system drive?
X99 | i7 5960x @4.6GHz | 64GB GSkill DDR4 | Nvidia GTX 950 | Samsung 950 Pro NVMe 256GB | Samsung SM961 NVMe 1TB | Samsung 850 EVO 1TB | Samsung MZ7PD256 SSD 256GB | Kingston 120GB SSD | WD Black 1TB x2 | G-Drive 4TB x2 | WD Elements 4TB | Audient ID14 | PT2020.5 | Windows 10 Pro
Old 03-19-2020, 08:56 PM
System drive does not need to be the fastest. Some have reported issues with old cheesegraters if they only run PCIe storage (with sata bays empty) but cannot confirm as my mac pro is a trashcan
Old 03-20-2020, 05:39 AM
weezul weezul is offline
Booting and opening applications, the difference between SATA SSD and Nvme is negligible, almost the same. It's the increase in access time that helps boot time the most, having to grab lots of different files from the drive. But the difference between a spinner and SATA SSD is absolutely massive.
However, loading sample libraries the speed difference becomes more obvious and beneficial. Of course the trade off, is NVMe storage costs more. Personally, I have NVMe as boot drive, scratch disk for heavy data workloads, along with sample libraries I use on the daily (basically, pt instruments). Then I have a large SSD for samples I don't use as often (Kontakt Library etc), another SSD for current session projects, and then 4x HDD NAS for master backup of files. Don't forget your cloud backup!!!
http://www.liamgaughan.com
Old 03-20-2020, 05:43 AM
What NAS do you have?
James Welch
Old 03-20-2020, 05:55 AM
lesbrunn's Avatar
OK. I didn't realize the difference between NVMe and SSD was negligible for the system. I use NVMe for my boot drive and NVme/SSD for audio and samples.
Old 03-20-2020, 06:53 AM
bobcharest bobcharest is offline
I just replaced all spinners with SSD, and I agree, the speed difference is wonderful. One laptop that I just bought had 250 Gb NvME drive. I replaced it with a 1 Tb NvME drive. The NvME was just slightly higher priced than the 1Tb SSD drives I used, but is less expensive than, say, Samsung QVO 1Tb drives.
Great to have such inexpensive choices!
Best Regards,
Bob Charest
__________________________________________
Macbook Pro, Mac Mini, High Sierra 10.13.6, Protools 2018.12.0
New Avid Link 2020.1 - launched today 1/16/2020 marianna Licensing & Accounts 8 01-16-2020 11:43 PM
drive choices for virtual instruments TZaudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-23-2009 11:22 AM
Drum recording: 3 room choices, 3 channels, 4 mic choices - pls lend your advice!! edgarbc1 Tips & Tricks 4 12-03-2009 08:40 AM
Usb Flash Drive Choices ? Anyone ? TommyT Pro Tools TDM Systems (Mac) 1 05-05-2007 02:11 PM
Hard Drive Choices mrguitarguy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 10-27-2004 02:18 PM
