Old 03-31-2021, 02:57 AM
priorytools priorytools is offline
Default Fairchild 670 ~ External Side Chain ?
Hi all. .
Does anyone know of an AAX 670 that has external side chain facility ?
Any help much appreciated . .
Cheers . .
~ 2019 Rack Mac Pro 3.2 GHz 16 core 384 GB RAM Catalina 10.15.7 / Pro Tools Ultimate 2022.12.0 / HDX 2 + UAD2 PCIe OCTO+QUAD / HD I/O's x 4 + 1 x 96io / Digidesign Pre's x 3 / Avid S6 M10-24 -V22.12.1.34 ~
~ Mac Pro 8 core - clover - 13 GB ram - 10.6.8 / HD5 / Pro Tools 9.0.6 / Magma PE6R4 ~ ARCHIVE RIG
~ Mac Pro (Early 2009) - 2 x 2.26 GHz Quad-Core-32 GB RAM-10.13.6 / Pro Tools Ultimate 2019.10 / Apollo 16 / Avid S3 ~
Old 03-31-2021, 04:46 AM
Default Re: Fairchild 670 ~ External Side Chain ?
Originally Posted by priorytools View Post
Hi all. .
Cheers . .
Only one that I can find that has one is the Avid 670 in the Complete Plugins bundle.
Jack
QAPLA!
Old 03-31-2021, 07:15 AM
Yes, but that doesn't behave correctly. It seems to use the "key" input & the source material. .
Old 03-31-2021, 09:32 AM
Are you saying the sidechain uses both the external sidechain along with the internal sidechain (if you have an external sidechain feeding into the plugin)? Please explain.
Jack
QAPLA!
Old 03-31-2021, 10:25 AM
With LAT/VERT engaged & a signal going in the key input, behaviour is not as required. .
Try it. On a stereo channel obvs . .
Seems to me there isn't really an external sidechain capability with the 670. .
Unlike other compressor plugins, which all have either a "key" or "external" button.
If it was properly implemented it would have a "key" or "ext" button + a toggle to select which path the sc is acting on. LAT or VERT.
Old 03-31-2021, 11:04 AM
You should have specified that you're working in mid/side. In regular stereo it works as it should. I know of no s/w compressor that does m/s and has external side chain that has a selection switch like you ask for.
Jack
QAPLA!
Old 03-31-2021, 11:59 AM
Exactly.
Old 03-31-2021, 02:50 PM
Avid. Any chance of this being implemented ?
I have a feeling it might well be popular.
And while you’re at it… ADC & stereo side chains please …
Thanking.
After all… your software is called “Pro” Tools.
Old 04-22-2021, 05:44 AM
simon.a.billington simon.a.billington is offline
Seeing this thread just made me realise that the two Fairchilds I have from Waves and IK don't actually have a sidechain either... WTF?!?
I do have the SPL Iron though. It's fundamentally based on a similar design, but they took it a lot further. It, at least, has a sidechain and by setting it's Bias to High and choosing a good Rectifier setting you can kind of get close. As long as you aren't one to split hairs!!
Old 04-22-2021, 05:49 AM
Hi Simon..
Do you know, , , ?
That's exactly what I did. . !
Nice bit o kit is Iron .
Thank you for your reply / suggestion .
HTML code is On
Is it possible to side-chain an EQ? Herkimer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 12-03-2009 06:00 PM
Impact Side Chain J2sound VENUE Live Sound Systems 5 07-14-2009 05:50 PM
How do I set up a Side Chain junglelabs 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 09-30-2007 10:49 PM
Side Chain ByPass Tips & Tricks 1 05-08-2007 12:33 PM
A better way to side chain? studiojb 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 04-24-2007 04:40 PM
