Clear all Clips crashs everytime
While runiing a song or standing still clear clips crashes Pro-Tools and eventually I am asked to re-book computer by holding etc.... Very large session with 128 voices 4 DSP, 136 plus tracks , etc... 9- out of 10 times, and yes I've done all the regular stuff, trough away pref. dae,digi set up, Pt Icon , zapp phee ram, stood on a chair, spun around three times went to lunch etc...
Later, Kurt [email protected] Intel duel Quad core PT 8.0cs3 HD4 D Command / D control |
Re: Clear all Clips crashs everytime
Time to sacrifice a goat.
Or provide more information.
Andre Knecht We’ll fix it in the shrink-wrap. (Frank Zappa) . |
the only thing I can think is CPU usagge is low.CPU usage is set to 99% could that be the problem. it sounds like a ram issue but i've replace all ram and had apple check it all out and it flys fine.
Does the problem manifest itself with the one session you mentioned only, or with all your other sessions as well?
all sessions, it also conisides with a DAE plroblem of 192 audio pops. Other people have found this to be a problem and it seems its bad DAE. By throwing away DAE pref. this all seems to go away. Sound s like a Bug to me.
While the popping sounds you mentioned are an ongoing concern that has been reported by a number of HD TDM users (including yours truly), the crashes triggered by the "Clear All Clips" command is a new one to me. By your description, I suspect there is something fundamentally wrong with your system. It could be your Digi hardware, software, but it may just as well be your Mac. It could be an incompatibility with third party hardware and/or software. Eliminate all possibilities, one by one. Have you tried resetting your computer's NVRAM? Repaired permissions? Run Cron scripts? Have you tested your RAM? Visually inspect and reaseat all cables, but especially your Digicables connecting the 192s to the HD cards. Look for bent pins or debris. Is your gear properly grounded? You could/should also try re-seating... • all your system's cards • TDM flex connectors • RAM • Internal Hard drive & optical ribbon cables, etc. Over the years, I've encountered problems that were caused by any of the above (by themselves, or in various combinations). Take your time and be methodical. I hope this helps.
I would like to resurrect this old thread because I've been having the same problem (PT quitting when I hit option-c "Clear All Peaks"). I have a PTHD Accel 2 system that I first used on a Mac G5 2x2 (the revision that was current in July/August of 2004) belonging to an associate of mine. Meanwhile, I have transferred this system to my own G5 2x2 (purchased June 2005). That should cut out a lot of variables (RAM, OS configuration, etc.). Software-wise, I went from 6.4 till 6.9 on the old machine (running Panther) and did a clean install of 6.9.3 on my new machine (running Tiger). The problem has persisted throughout all these permutations, which leads me to believe there might be something wrong with my TDM hardware (all other variables having been exchanged). I ran Digitest and it passes both my cards without problems though. Since this is the only thread I have found on the subject it doesn't appear to be a known bug. Kurtstudio, did you run into any new info on this in the meanwhile? Regards, L |
Exporting Clips as WAVs, clips dont highlight in list | gigantorbuzz | Pro Tools 10 | 6 | 08-05-2013 01:07 PM |
Clear selected clips shortcut not working hd 10.3.2 | dgoodi22 | macOS | 7 | 02-08-2013 04:49 PM |
Cross fades are not between clips but at the end or beginning of clips | phatbeatstudio | Pro Tools HDX & HD Native Systems (Mac) | 2 | 09-10-2012 02:08 AM |
Protools 7 Crashs | B Hind | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 11-10-2005 11:06 PM |
Clear all clips crashes, Sometimes! | Kurtstudio | Pro Tools TDM Systems (Mac) | 0 | 04-05-2005 07:59 PM |
