#31
Re: Recording levels? -18dbs
Actually 0dB.VU is -20 dBFS while 0dB RMS is -18dBFS!
Bob's room 615 562-4346 Interview Artists are the gatekeepers of truth! - Paul Robeson |
#32
Are you referring to the idea that the 1kHz sine wave you can get out of the Avid Signal Generator plug-in should be treated as an RMS signal and not a peak signal?
I thought that you could load the Avid Signal Generator plug-in on a mono output, set it to -20 dBFS, and calibrate the analog audio output to measure 1.228V RMS on a voltmeter. I thought that calibrated signal (1kHz @ -20 dBFS = 1.228V RMS) could then be sent to a VU meter which would then be zeroed to this signal. 1kHz at -20 dBFS = 1.228V RMS = 0 VU Is what you are describing related to this archived thread where those of us who participated in it determined that the BombFactory Essential Meter Bridge should have been renamed to the BombFactory Essentially Useless Meter Bridge?
Jonathan S. Abrams, CEA, CEV, CBNT Apple Certified - Technical Coordinator (v10.5), Support Professional (v10.6 through v10.10) |
#33
Most software metering is a train wreck because developers don't pay any attention to the SMPTE standards. A VU meter is not an RMS meter.
I swear you need to know more about audio to use this stuff properly than you seem to need to know in order to get hired by a developer. I'll crawl back into my cave now.
#34
Most Analog VU Meters can be calibrated to any level...
those who dont can also be calibrated using digital tricks, like DSP Mixer or a Digital crossover... the procedure to calibrate a VU meter is to generate a Sine Tone, at desired Level, and adjust VU Meter to display usually 0dB, can also be done with +3dB or -3dB or -6dB. calibrating an Analog VU Meter to show 0dB with a Digital Sinewave at -18dBFS gives a Low RMS Target Level.... calibrating an Analog VU Meter to show 0dB with a Digital Sinewave at 0dBFS gives a High RMS Target Level... Like Most CD´s from the Loudness War. Sinewaves are usually -3dB RMS from 0dB, or +3dB Peak from 0dB. RMS is the 70,7% aprox. of a Symetric sinewave. Average is the 63.66% aprox. 0dBV = 1volt RMS, 2.8284v Peak. 1.227653v RMS = +4dBu. 0dBu = 0.7745 volt ("0.77459667") consumer audio −10dBV = 0.3162 volts = −7.78dBu DA converter must have enough headroom for +3dB VU. Some Professional Analog Equipment with +/-18volts DC power supply, or +36vdc Class.A, can have upto +32dBu Peak Output.
--->If you don't like what i wrote: Click: JuanPC Click: View Public Profile Click: User lists^ Click: Add to ignore list. Solved. Last edited by JuanPC; 05-23-2016 at 06:02 PM. |
#35
This thread is a good read and should be a sticky for young up and comers!
HD Native Pcie, PTHD 11, PT12 Vanilla, Omni, Lynx Aurora 16, 192 I/O (16 in/8 out), 24 Fader D-Command, lots of preamps and compressors. MacPro 5.1 (12) Core (2009 MacPro 8 Core Upgraded to a 12 Core MacPro), 56 Gig Ram, SSD System & 3 - 2TB Drives, OSX 10.9.5, Windows 10 Via Bootcamp |
#36
Steve
Steve Shepherd Extreme Mixing |
#37
#38
Louder sounds better but you need to turn up the monitoring volume and leave recording levels on the safe side.
Of course, if you are recording a synth pad that has little to no dynamics, the safe side is considerably hotter than percussive material, such as kick and snare for example. Meters are not fast enough to tell you the truth about transients Sent from my iPhone using Tapatalk
#39
Well that was kind of true with 16-bit sessions (96dB dynamic range) but is NOT necessary with 24-bit sessions until AD converters magically give +144dB dynamics Sent from my iPhone using Tapatalk
#40
Steve
Best Recording Levels | spaceman | Tips & Tricks | 102 | 11-26-2011 06:53 PM |
Low recording levels | Krish | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 09-29-2011 05:11 PM |
Recording Levels | jawjam | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 12 | 08-20-2004 01:32 AM |
recording levels | Graeme Oxby | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 17 | 01-25-2003 12:06 AM |
Recording levels | nickair | Pro Tools TDM Systems (Mac) | 2 | 06-23-2000 10:11 AM |
