HDX card not recognized in new install
Hey, need some help here.
I just upgraded to PTHD12 HDX from PT10 HD. New PC build, components from the forum: Asus X-99II MBO i7 3.6 GHZ 6 core 32GB Corsair Ram SSD System and Audio drive GeForce 750ti Video Windows 10 Everything looks good, went through my upgrade and everything is listed in my iLok mgr account (PT HD, Digi Link, etc). I can install PT 12, but ti does not see my HDX card. In Device Mgr, the Avid HDX card has the dreaded yellow hazard icon. I've tried multiple install and uninstalls, trashed pref, tried 12.8 and 12.7. Tried calling Avid support earlier, but even though my account says I have support through 2018, when I give my system ID, no support/dice. Thoughts on getting my card in clean install state in device mgr?
PT Ultimate 2020.3.0 1 HDX Card Lynx Aurora 16 (2) Windows 10 Pro 1909 ASUS X-99 II Intel i7 32GB RAM Gigabyte GeForce GTX 1050 Ti 4GB www.doylemusic.com |
Re: HDX card not recognized in new install
You need a driver for the HDX card.
That's what the yellow triangle means Let me look online to see if I can find a link
The link said they are in your master account.
It is the HD Driver, it needs to be installed on your system http://avid.force.com/pkb/articles/download/en379411
The hdx driver is installed when you install pro tools. What is hapowni by is you need to turn off secure boot in the bios of the Asus motherboard. Fyi the avid hdx driver isn't signed correctly and windows 10 is blocking it. To unblock it, turn off secure boot on your Asus motherboard.
https://www.google.com/url?sa=t&sour...4JtEUw&cf=1
Brandon Howlett Vibe Audio Post, Inc. Re-recording Mixer Custom Build CPU, HDX 1, Omni, 192 I/O Digital S6 M10 24 fader Satellite Mac Pro, HDNative, 192 I/0 Black Magic HD Extreme |
This he needs this.....it's a separate install.
I have the driver, dont think thats the issue. Ive tried installing the driver separate as you showed but it also installs with PT.
Curious what version of Windows 10 you are using? I had the same issue with LTSB with my ASUS board. Avid said that the HD driver signing changed at 12.6. My current install/drive image is pre 12.6. I went back to Creator from LTSB because it is based on the Anniversary which doesn't have the svchost management optimizations. Frankly I didn't feel there was a significant difference in performance using LTSB. Avid said they don't support LTSB also.
I don't recall, (sigh), however I believe I tried a fresh install of Creator and had the same driver signing issue so I reverted back to my pre-12.6 drive image which for some reason doesn't have the driver signing issue when updating post 12.6 and I am able to keep secure boot enabled in my bios. Just a note, I am not using the latest bios rev for my board because of an issue with the Asus Thunderbolt addin card , which is a different issue of reliability, and a not driver signing related issue. From Avid: The fact that it (driver signing) works with HD driver 12.4 and not 12.6 is because signing for the HD Driver changed with 12.6. So without the updates it will not work properly. I hope this answers your questions. Kind regards, (Avid rep Name removed) case ID: 03198238 Avid Customer Support | Audio Sent from my iPhone using Tapatalk Pro |
Sweet
Did you check for the DigiLink I/O License?
Sent from my ONEPLUS A5000 using Tapatalk |
HDX card not recognized | JSeamster | Pro Tools HDX & HD Native Systems (Win) | 14 | 11-14-2018 03:56 PM |
HD3 3rd card not recognized | dhumez | Pro Tools TDM Systems (Mac) | 12 | 12-29-2011 01:09 PM |
192 not recognized from Core card, but IS from Accel Card. Advice? | Mt.Everest | Pro Tools TDM Systems (Mac) | 5 | 05-24-2010 09:14 PM |
MiniGrand Plugin not recognized after re-install | cjackson111 | Pro Tools M-Powered (Win) | 3 | 08-16-2009 08:41 PM |
Hardware not being recognized on new install | growles | Pro Tools TDM Systems (Mac) | 6 | 05-05-2006 02:40 PM |
