Old 09-29-2010, 01:00 PM
play4theworld play4theworld is offline
Default Bassy finger picking, remedies?
I was recording my acoustic and it usually sounds great, but when I finger pick it comes out really bassy sounding and no good overall.
Is there an EQ or a little trick to fix this?
its a steel string.
Old 09-29-2010, 01:02 PM
audiogeekzine audiogeekzine is offline
Default Re: Bassy finger picking, remedies?
move the mic further away from the sound hole.
@theaudiogeek
| www.EPICSounds.ca | www.AudioGeekZine.com | www.HomeRecordingShow.com |
Old 09-29-2010, 01:12 PM
Think i tried that, I'll try it again to make sure.
Old 09-29-2010, 01:26 PM
i messed around with distances.....i think I may just need a different (quieter) room for the sound I want.
Old 09-29-2010, 04:29 PM
ondruspat ondruspat is offline
Finger picking is always more bassy, at least if you don't have any nail (like me!!). It's mostly a matter of mic placement (new strings don't hurt either), try pointing the mic closer to where the neck meets the body or putting the mic at an angle instead of straight at the guitar. Keep moving it around and listen to it in different positions.
"Sometimes having limits keeps you sane"- Albee1952
Old 09-29-2010, 05:07 PM
You might also go for a brighter mic when recording finger-picking. A shelving low EQ cut may help your track.
Old 09-29-2010, 06:13 PM
Cool thanks guys,
and on the strings i use exps so theyre pretty much new till there dead.
Old 09-29-2010, 07:36 PM
anothercolour anothercolour is offline
Small diaphragm condenser mic pointed at the 12th fret, and subtractive EQ on the low end.
Old 10-27-2010, 06:46 AM
muchogranderobot muchogranderobot is offline
i agree with anothercolour. maybe add a little angle from the 12th fret pointing towards the sound hole and pull a little muddyness from around the 200hz range.
Old 10-27-2010, 06:54 AM
daeron80 daeron80 is offline
I like to add a second mic near the head for finger style. You might be amazed how much sound radiates from the headstock, and it's all bright, sparkly stuff on most guitars.
David J. Finnamore
PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max
PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB
11r too bassy and distorted help! XCorrupt Eleven Rack 21 11-21-2010 05:09 PM
OT:Trigger Finger Joe Evans 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 02-01-2006 04:37 PM
Alplitude has pulse hissing, remedies? meandeanmachine 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 10-19-2004 09:24 PM
bassy acoustic guitar drummerfreak33 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 04-21-2004 04:32 AM
Guitars in the mix are muddy,bassy platinumx99 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 08-28-2003 06:30 AM
