  #451
Old 10-23-2013, 11:52 PM
Aussie Mick Aussie Mick is offline
Default Re: -9171 and -9172 errors with Pro Tools HD 10.3 on HDX
Hi Boe,
I have the same setup as you and I get this problem with no audio track just one Native Instrument Kontakt 5 playing drums.
Drives me made.
If someone can help us great.
Processor 2 x 3.06 GHz 6-Core Intel Xeon, Memory 64 GB 1333 MHz DDR3 ECC, ATI Radeon HD 2600 XT 256 MB, OS X 10.8.5 (12F45), HDX2 4 x 16 x16 HDi/o, Sync HD, Pro Tools 10.3.6 and Pro Tools 11
Mick
  #452
Old 12-06-2013, 05:01 PM
rstreber rstreber is offline
Any word on stability with Mavericks / PT11.03 / XHD? Are these problems solved?
  #453
Old 03-08-2014, 08:25 AM
Will Russell's Avatar
Will Russell Will Russell is offline
Hi everybody,
So I just installed my brand-new HDX card, and running ProTools 10.3.8 I'm overwhelmed with 9171 and 9172 errors. Some sessions, simple sessions, won't even run without the buffer set 1024. What's up with this? Totally lame for a $6000 card.
Will Russell
Electric Wilburland Studio
https://linktr.ee/wilburland
M1MAX Mac Studio OS 14.4.1, PT2024.3, HDX, S1/Dock
M1 PRO MacBook Pro OS 14.4.1, PT2024.3, BabyFacePro FS
  #454
Old 03-08-2014, 08:31 AM
Boe Larsen Boe Larsen is offline
Originally Posted by Will Russell View Post
Hi everybody,
Yep - join the club. However most of the plugs I use are now AAX, so I have deleted PT10 completely - and I don't these errors on PT11HD.
Boe Larsen
Producer
www.millfactory.dk
  #455
Old 03-08-2014, 10:40 AM
Hanswurstlsepp Hanswurstlsepp is offline
Hi everybody,
How is it with PT11HD ?
Cheers, STeff
MacPro5,1 ; 6-Core Intel Xeon 3,46 GHz, 32 Gig Ram, NVIDIA Quadro K5000 with 3 displays connected  OSX10.15.7  Pro Tools|HDX Ultimate 2023.6  HD I/O&192Digital&96&96i I/Os  D-Command ES  4xUnitor8 & 2xAMT8
  #456
Old 03-08-2014, 10:44 AM
So far, so good!
Will Russell
  #457
Old 03-09-2014, 05:53 AM
Eric Seaberg's Avatar
Eric Seaberg Eric Seaberg is offline
We've been running 10.3.8 on a MacPro HDX2 without any issues whatsoever, and we're usually tracking 80+ tracks at one time with 128-IO. Still on Mtn Kitty, and we just made sure that all of our MacPros, including 4-HD Native systems, were clean of the extra junk that throws PT into a stall. Look for instructions to turn NOTIFICATIONS OFF, as well as SPOTLIGHT. This will solve a lot of issues.
As fas a plugins, remember that 10 and 11 do NOT store any of their necessary files in the same places, which is why they can coexist. All plugins are separate.
Good luck...
Eric Seaberg • San Diego, CA
A.E.S., I.E.E.E., S.M.P.T.E., S.P.A.R.S.
  #458
Old 03-15-2014, 11:23 PM
stopxwatch stopxwatch is offline
I believe I may have found a solution for mac users.
I went into /System/Library/CoreServices/ folder and opened the Expansion Slot Utility. In this utility I made sure that my graphics card slot was set at x16 and the HD Native card was set at x8 (not x4)! You may have to move your HD card to the appropriate slot to achieve this.
The Playback Engine in Pro Tools is set to 128 buffer an 7/8 processors running at 99%.
This completely eliminated all my errors!
I hope this may help some.
  #459
Old 03-16-2014, 07:30 AM
Benny_Cha_Cha Benny_Cha_Cha is online now
Seems this works only for older machines. See: http://support.apple.com/kb/ht2838
Ben Rubin
Producer//Mixer//Bassist//Composer
benrubin.com
PT Ultimate 2024.3, Mac Studio M1 Max, 64Gb RAM, Mac OSX 13.6.4, SSD sample drive,
Neve 8816, HD Native Thunderbolt, (2) Lynx Aurora 16, Benchmark DAC-1/ADC-1
  #460
Old 03-17-2014, 07:54 PM
You are correct.
It looks like that the HD card should be placed in slot two then since, from my experience, x4 is not enough for the Hd card an the graphics card usually sits in slot 1.
Pro Tools 10.3 9171 and 9172 Errors Tops3b Pro Tools HDX & HD Native Systems (Mac) 20 07-14-2013 03:11 PM
-9171 and -9172 errors constant...Sandra attached wrachilla Windows 12 05-09-2013 09:19 AM
UAD triggering 9171, 9172 errors? xq3js macOS 7 03-22-2013 11:47 PM
Dae errors -9171 after installing 10.3.3 TCM Pro Tools HDX & HD Native Systems (Win) 3 02-06-2013 10:18 AM
10.3.3 Major Fail....9171, 9172 and 9129 Errors Tops3b Pro Tools HDX & HD Native Systems (Mac) 3 12-21-2012 07:21 PM
