Old 04-28-2019, 10:35 AM
dez811 dez811 is offline
Default Select all mixer channels with control app
Hello I’m trying to mute all plugins and sends in a project at once using the control app but the only way I can get it to work is to option click on a track then I can select the bypass all inserts button in the app. Is there another way.
Old 04-28-2019, 12:40 PM
BScout BScout is offline
Default Re: Select all mixer channels with control app
Bypass all insert plugins: Shift+A (select tracks and then Shift A). If that's not assigned to a soft key in Control, you can do so.
Don't know about bypassing sends
Old 04-28-2019, 03:20 PM
I was trying not to use the keyboard to do it but what I figured out was to assign do to all to a button, then I can click on one of the tiles above the soft key page to select all then hit the bypass all inserts or bypass all sends button
How to select multiple channels and lower faders Firechild Pro Tools TDM Systems (Mac) 14 03-07-2011 10:04 AM
cannot select channels on 003 rack + atkramer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 01-27-2011 10:04 AM
Can you select multiple channels on D-Control? johnnyv ICON & C|24 2 08-24-2009 09:27 AM
How did I select channels? idris ICON & C|24 6 12-24-2008 12:42 PM
Can't select midi channels Niljam 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 03-08-2003 05:12 AM
