PCIe Chasis Other than Magma???
Does anyone own a PCI Chasis or PCIe chasis other than Magma or Digidesign which iz built by Magma?
I have a HD4 PCIe but no chasis to put these babies in. Thanx M2E
New System: Macbook Pro M1 Max/16 gigs of Ram/Monterey/3 UAD Quad Satellites/2 PCIe Quad UAD cards/Waves Digigrid/Antelope Zen Pro/OWC 3 Slot Thunderbolt PCIe unit/Over 1400 plugins (Beta Tester for 15 different companies) YouTube Channel https://www.youtube.com/watch?v=HaZYp2wNomc |
Re: PCIe Chasis Other than Magma???
Im selling my Digi PCIe expansion chassis 3233946544 kyle
Hi M2E
I believe Digi does not support expanded PCIe systems larger than 3 cards and only when its installed inside the machine, as the mac pro and G5s that are PCIe have only 3 slots available, Only PCI HD Cards systems installed into a expansion chassis like Magma and Digi with the use of a PCIe host card. Apparently (ive been told and do not quote me on this) there is a problem when the PCIe cards are not installed Inside the computer that has PCIe slots, and Digi hasnt been able to find a way around it. I found this on the digi page on HD PCIe systems: The Mac Pro requires ONE of the following Pro Tools|HD configurations: HD PCIe Cards — installed inside the Mac Pro Please Note: 48 voice/single DSP or 96 voice/2 DSP engine (at 44/48K) are not supported HD PCI Cards — installed inside the Digidesign Expansion|HD or Magma PE6R4 6-slot expansion chassis Pro Tools|HD PCI and Pro Tools|HD PCIe cards cannot be combined in any system For more information, see the Digidesign Expansion|HD 6 Slot Expansion Chassis and Magma PE6R4 Expansion Chassis compatibility pages How did you end up with a HD4 PCIe anyway? I dont see any extended systems using PCIe cards, I might be wrong tough? Good luck www.borismilan.com |
Thanx M2E
I hear you.
I assume that eventually whatever the problem is will be solved and you'll be able to get more HD cards, is good that you have mac pro, fill it up with more Ram, that should help till then. Hang in there good luck www.borismilan.com |
Magma Chasis PCI-7-RX and PT | Moncarz | Pro Tools TDM Systems (Mac) | 5 | 04-02-2011 03:15 PM |
Where can I find a list of qualified Magma Chasis for PCIx to PCIe? | a2zproductions | Pro Tools TDM Systems (Mac) | 21 | 01-14-2011 02:09 PM |
New Mac 2010 with Magma chasis ? | T_S_Harris | Pro Tools TDM Systems (Mac) | 10 | 12-29-2010 10:03 AM |
PCI to PCI-e with new Magma Chasis | NK | Pro Tools TDM Systems (Mac) | 2 | 10-24-2006 12:53 AM |
Magma PCIe to PCI chasis announced | ricren | Pro Tools TDM Systems (Mac) | 8 | 08-19-2006 02:36 PM |
