Old 04-27-2020, 07:59 AM
Marsdy Marsdy is offline
Default Re: Sonnet M.2 4x4 PCIe Card fan noise or OWC Accelsior
Originally Posted by lucienpalmer View Post
Technically they say “Aggregate transfer speeds” which I personally think is a little misleading advertising gimmick. All they are saying is that the total possible data moving adds up to 12GB/sec. because they allow each of the 4 chips their own direct PCI connection, that’s probably 3GB per chip and they add it up for advertising. I’ve never heard of JBOD being faster than RAID 0.
I think they were talking about transfer speed of data from individual M.2 cards and not the date transfer capability of the card itself.
This is their exact claim:
When installed in a Windows PC’s PCIe 3.0 slot with four SSDs formatted in a RAID 0 configuration, the card is capable of 8,500 MB/s transfers. Aggregate transfer speeds from four non-RAIDed SSDs of up to 12,000 MB/s are possible!
Interesting that they would claim RAID 0 speeds of 8,500 MB/s on a Windows PC. I wonder if that’s why Mac users are getting less than that or as you say, it’s advertising hyperbole.
Personally I’ve always found a slight performance penalty when using RAID 0. Performance is not quite twice the aggregate speed of two SSDs running separately. In my Blackmagic Multidocks, one drive maxes out at 384MB/s, two drives in RAID 0 - less than 750MB/s, three drives less than 1000MB/s.
Dave Marsden
UK
Old 04-27-2020, 08:02 AM
JFreak's Avatar
JFreak JFreak is offline
RAID0 is simpy extending one drive capacity with another. No software can write to both drives round-robin, it is the card that does RAID which determines what to use. In worst case scenario it fills first drive first and only begins to fill second drive once first one is full.
Janne
Old 04-27-2020, 08:09 AM
lucienpalmer lucienpalmer is offline
I see what you are trying to say about a ‘penalty’, because it doesn’t exactly double with two drives in a RAID. But I interpret that completely different. It’s a benefit. A boost. By themselves, your drives could only do 384, and now in a raid, they are boosted to 750. And with three drives, even better speeds.
That’s a good thing! To me, that’s all benefit. You aren’t losing out on anything.
Pro Tools Ultimate, HDX3 & MTRX + HD MADI
7,1 MacPro, 3.2GHz 16-core, OSX 10.15
S6 M40 48-5, panners, MPM,Dolby Atmos RMU
AJA Kona LHi, Sync HD
www.ToolshedAudioPost.com
www.TheToolshedStudio.com
Certified for Dolby Atmos Home Entertainment
Old 04-27-2020, 08:14 AM
Nope, you are getting RAID 0 confused with JBOD.
Just a Bunch Of Disks simply extends the Drive capacity of all the drives connected. The advantage is that you can mix-and-match different sizes, but there is no other benefit. It fills the first desk then moves on to the next, and then the next, and so on.
RAID 0 is a striped volume. Performance is increased because it alternates as it writes to the disks.
Old 04-27-2020, 08:19 AM
JFreak's Avatar
Hopefully, that is the key word. Usually something between worst case and best case, but you cannot just throw numbers of best case scenario because real world performance is nowhere near.
Janne
  #16
Old 04-27-2020, 08:45 AM
But it is? I find that response really confusing. Are you saying the RAID 0 doesn't boost performance? It does; a lot! Putting two SSD's together in a RAID 0 almost doubles the performance. I do it all the time.
My main project drive in the system I'm working on right now is two Samsung SSD's in a RAID 0. Individually, one of those drives by themselves tests at 449 MB/sec write and 493 MB/sec read. After putting two of them together in a RAID 0, I get 716 MB/sec write and 894 MB/sec read.
The confusing part is when companies start using things like "aggregate speed", Which I think is marketing BS. It's not like you can copy a file at the 'aggregate' speed. That like saying my car is going 100 mph, so all four of my tires have an aggregate speed of 400 mph. It sounds great! But it doesn't mean much in the real world. Although to be fair to Sonnet, they used an example of making one SSD chip your system drive, then putting the other three in a RAID. So what I think they are trying to say with aggregate speed is that there won't be any bottlenecks if the chips are operating separately at the same time.
But you'll never get close to the speeds of a RAID 0 with JBOD. Especially with 4 chips in a RAID 0.
  #17
Old 04-27-2020, 08:49 AM
JFreak's Avatar
It does! Between zero and hundred percent with two identical drives. Ads tout double performance but it isnt guaranteed
Janne
  #18
Old 04-27-2020, 10:03 AM
Originally Posted by Michael Carnes View Post
I have exactly that configuration you're asking about--Sonnet card, set up as RAID-0 in a Mac Pro 7,1. I don't quite get 8,500MB/S in the Blackmagic speed test, but I'm up there around 7,600. It sure beats my previous setup of SSDs in an external TBolt enclosure. I got about a tenth that speed.
Thanks for the info Michael. How is the fan noise?
  #19
Old 04-27-2020, 01:53 PM
Michael Carnes's Avatar
Michael Carnes Michael Carnes is offline
Development Partner
Thanks for your insights Michael.
Speaking of fans - can you comment on how loud the fan gets on the Sonnet card?
I don't think the fans are loud but I don't really know. My computer's in a hall closet with just a few cables coming through the wall of my studio.
I’m guessing you’re not a keyswitch guy! I am so less likely to run out of tracks fortunately!
I'm crap on the keyboard. I was (and suppose still am) a guitarist, but I'm typically importing from a score editor anyway.
  #20
Old 04-27-2020, 02:00 PM
Development Partner
I’ve been wondering if RAID 0 is the best way to go in this situation. Obviously there’s the convenience of one big volume but other than that - I’m thinking the aggregate speed of multiple drives might be cumulatively faster in JBOD mode. Sonnet are quoting up to 12,000MB/S as an aggregate speed for all four drives running separately.
Perhaps. You can stick brass on one drive, percussion on another, strings on another, etc. I actually tried something similar on my older system. But if you're writing something really heavy on brass, you're trying to get most of the orchestra off one drive. Or you could add an expansion pack that overflows a drive and that forces you to reorder all of your libraries. I figured with a RAID-0, that I'd get consistent performance no matter what.
FS : AVID Native PCIe Card With Mac Mini Server & Sonnet Rack & Pro Tools Keyboard rdraudio Buy & Sell 0 02-04-2019 03:53 PM
Installing 3rd card PCIe went wrong... noise Inthebox Pro Tools TDM Systems (Mac) 4 05-11-2018 09:30 AM
Sonnet Echo Express SE-II thunderbolt 2 chassis and eSATA PCIe card John_Toolbox Buy & Sell 1 02-05-2015 08:12 AM
Sonnet Echo Express III-R Thunderbolt PCIe Expansion Chassis Andi R Pro Tools HDX & HD Native Systems (Mac) 22 02-05-2014 10:35 PM
sonnet card in uk? neil conti 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 11 11-28-2002 11:43 AM
