macbookpro-expresscard slot
hello,
i would like to know if we can use the expresscard slot for either ... 1) 002R interface ala expresscard to firewire with drives on the macbookpro's firewire 2) firewire 800 or 400 drive ala expresscard to firewire with the 002R on the macbookpro's firewire if either of these do not work ... i guess i would have to go the mbox route .. thank you cheers john
What are you trying to do?
i do not know how i can be any clearer than what i posted ... if this does not make sense to you than just disregard .. thank you for looking
cheers john
I understood what you were asking. I was looking for more information about what your ultimate goal was, beyond the obvious...
....but nevermind. |
there is no more information needed to answer this post .. you either know if either of the two senarios work or you do not .. if you knew you would say you do ... if you do not, you should not answer the post with what are you trying to do or what is your ultimate goal beyond the obvious .. there is nothing beyond the obvious ..
i know you mean well but in this case i need an answer not a tennis match ... again i thank you for looking and cheers ... :) john
You can use the SIIG FW400 express firewire card for the drive, connecting the 002 direct to the mac. Theres also no reason why you cannot chain the two firewire devices together, thats what us Macbook users do.
iMac i5 2.8GHz, Macbook Pro 2.4GHz, Pro Tools 10/11, MOTU 828mk2, Presonus Digimax FS, Presonus Firestudio Project, TC Konnekt 24D --- iCON Photography |
love the name Dougfather ...
siig card .. cool .. i will try the daisy chain thing also .. have a couple friends that this was not working well with that setup ... i need to look up whether the 002R is first in the chain or the drive ... thank you for the response .. cheers john
found it in search .. drive first .. if anyone else is looking for this info
cheers john
I have my 002r is connected to my MBP firewire port and my 500GB Oxford drive is connected by the FW800 Express card port, it works like a dream!!!!
While it's not technically supported, I can confirm that the SIIG FW400 expresscard works with either the drive or interface attached to it (personally I have the drives attached.).
One kind of stupid thing about the card that they don't tell you in the specs and don't make very clear anywhere is that, if you want to power anything via FW bus power (like an MBox 2 Pro, for instance), you'll need the separate power adapter to connect to the card. This is the card: http://siig.com/ViewProduct.aspx?pn=NN-EC2012-S1 And this is the power supply: http://siig.com/ViewProduct.aspx?pn=NN-ADAP11-S3 |
will cards from 7 slot magma/digi chassis work with 12 slot? | digidesigner | Pro Tools TDM Systems (Mac) | 0 | 02-02-2008 04:17 PM |
MacBookPro - Magma 4 Slot ExpressCard Chassis - PT | Andi R | Pro Tools TDM Systems (Mac) | 3 | 12-26-2007 06:49 AM |
G4 upgrade, the Six Slot Problem, where to slot the Digi001 interface card | H E A D W E R K ' N | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 11-14-2002 08:15 PM |
Slot Order for PTHD5.3.1 + AV Option 5.3.1 + Magma Chassis 13-Slot + PowerMac G4 AGP | Samhein | Pro Tools TDM Systems (Mac) | 1 | 06-27-2002 11:39 AM |
Slot Order for AVOption/5-Slot Mac & Expansion Chassis | Samhein | Pro Tools TDM Systems (Mac) | 0 | 05-01-2001 09:40 AM |
