Old 11-07-2013, 08:10 AM
JohanW JohanW is offline
Default MS Surface Pro 2
Hi!
Has anybody been trying MS Surface Pro 2 or similar with Pro Tools 11. I know it is not supported but it's just for on the go easy editing, tracking, config, preparation, play around.
I don’t want an ordinary laptop since it’s not as portable as the Surface and the Surface would make it possible to control my soundcard (RME UFX) with the touch screen. For mixing, serious tracking and other work I have a top spec stationary computer.
However the Surface Pro 2 just has one USB-port (USB3) so I will need a good USB3 hub to make it possible (and that seems hard enough). I would need to connect a soundcard, an external hard drive, an Ilok and a midi-keyboard.
Thoughts?
Regards
Johan
Old 11-07-2013, 11:40 AM
JoelG's Avatar
JoelG JoelG is offline
Default Re: MS Surface Pro 2
By the specs, Pro Tools should work. With the exception of Windows 8.1:
Note: Window 8.1 is not supported at this time. Avid will announce official support here when testing is completed. I think others have had success with it though.
I'm not sure if Pro Tools does any checks on the form factor of the "computer" it is running on, so I cant see why it wouldn't work, but no guarantees.
Surface Pro 2 Technical Specifications
Windows 8.1 Pro
Storage* & Memory
64/128GB 256/512GB
4GB RAM 8GB RAM
Resolution: 1920 x 1080
CPU & Wireless
4th generation Intel® Core™ i5 Processor
Not much of an answer. :)
Joel
Jam Space:
HP Elite 6300 / Core i5 3770 / 24GB RAM / Win 11 Pro
Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626
Home:
Asus B450 Pro4 / Ryzen 5 2600 / 32GB RAM / Win 11 Pro
Rig:
Eleven Rack / ART SLA1 / Two 2x10 Passive Monitors / FCB1010 w/ EurekaPROM
Old 11-09-2013, 03:23 AM
Thanks for the replay.
Do I get it right if I can store the ILok-licenses on the hard drive so I don't need to use the USB for the ILok key?
Old 11-09-2013, 05:20 AM
ondruspat ondruspat is offline
No, the iLok key is required.
"Sometimes having limits keeps you sane"- Albee1952
003 control surface (As audio) & control 24 as surface crizdee ProControl, Control|24, Command|8 7 01-04-2016 12:30 PM
Mix Surface and 2.7 zcondren Artist Series 4 03-28-2013 02:11 PM
002 surface protools123 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-07-2011 06:22 PM
002 as control surface only miketeachesclass 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 07-15-2010 11:56 AM
MC Mix with 002 surface?? pdivietro 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 06-17-2009 11:07 PM
