Old 06-24-2019, 04:33 PM
Eric Lambert's Avatar
Default Best/Simplest way to get System Sound patched into PT
Source-Nexus is designed to take the output of your Mac and pipe it into ProTools (it shows up as a plugin in PT) but I'd rather not pay that kind of money for this basic task. Is there another simple and easy way to instantiate a plugin on a track and have the Mac's system output fed into that?
Old 06-24-2019, 07:38 PM
sw rec sw rec is offline
Default Re: Best/Simplest way to get System Sound patched into PT
If your interface has a spare pair of inputs, route the MAC output to those inputs.
Old 06-25-2019, 04:10 AM
Would Jack work?
http://jackaudio.org/downloads/
Old 06-26-2019, 04:45 PM
Neither a hardware connection nor Jack will fit the bill here.
I can't imagine that only Source Elements makes such a connector between the System Output and ProTools.
Old 06-26-2019, 06:10 PM
Mind explaining why the h/w connection won't work for you?
Old 06-27-2019, 08:11 AM
I think you might be able to get this to work with Rogue Amoeba's Loopback and something like Blue Cat's Patchwork or DDMF Metaplug, but I haven't tried it - personally I have a coreaudio interface (Metric Halo ULN8) tied into my HD I/Os via AES so it's pretty easy for me to move audio between system i/o and pro tools i/o.
http://www.richbreen.com
Old 06-27-2019, 12:03 PM
Or if Apple still has it take the audio output of a Mac using a digital cable (the output used to do both audio and digital on the same connector) to a digital input on your regular audio interface.
Old 06-27-2019, 01:48 PM
I'd forgotten about Rogue -- taking a look. Thanks (again) Rich.
Old 06-27-2019, 04:25 PM
weezul weezul is offline
I use the loopback of my RME. Works great. Set MacOS outputs to 3/4, click loopback and then record inputs 3/4 while the channel in PT is muted. Don't unmute it until you're done though!
MacBook Pro: 16GB M1 Pro 8c
Hackintosh: MacOS Catalina, i7 6700k, 32GB RAM, RX580
Pro Tools Studio, RME RayDAT PCIe
http://www.liamgaughan.com
Old 06-27-2019, 05:42 PM
I have a friend who does the same. No such luck with my Avid IO, ironically.
Mix minus for talkback when patched to other studios ..Help! djrobbie Post - Surround - Video 12 06-03-2007 09:34 PM
Mix minus for talkback when patched to other studio via ISDN djrobbie Pro Tools TDM Systems (Mac) 6 05-28-2007 08:28 PM
Control surface for HD - simplest? brianjanthony Pro Tools TDM Systems (Mac) 3 05-20-2006 03:01 PM
Simplest Instructions? Sam F Digidesign Hardware & Software 1 04-07-2003 06:43 PM
Simplest way to reverse a sample? Brickdog 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-17-2002 10:28 AM
